1964 Ford 600 Motor
1964 Ford 600 Motor
Trying to find out what motor my 1964 3-ton F600 has, as I need to get a rebuild, or an upgrade to go onto the same tranny. It has a V8 Gas, 5 bolts holding on each rocker cover. Engine casting numbers barely visible, but something like C4AE 6013A
Truck made in Oakville Ontario
SERIAL: 4816074L - 182562F
ENGINE/TRANS: RN-5H/D2653
4 = V8 engine (probably a 330 2V M/D FT .. based on the C4AE-6015-A* block casting number).
81 = Conventional Cab.
60 = 600 series.
74 = 174" wheelbase.
L = Left Hand Drive.
182562 = 1964 Numerical Sequence of Assembly, the trucks specific serial number.
F = 19,500-26,000 lbs. Gross Vehicle Weight Rating range.
*1964/67 FT 330 2V M/D shares some parts with the FE 352. 1968/78 FT 330 2V M/D shares some parts with the FE 360.
51MHF5
16
10-03-2013 11:15 AM
