Help with nonworking cruise control
Old Jun 13, 2017 | 01:45 PM
idt-572's Avatar
idt-572
If you put a LED third brake light bulb EN could it cause the cruise control to stop working ? And could you add a resistor in that circuit to fix the problem?
Old Jun 13, 2017 | 01:53 PM
knottyrope's Avatar
knottyrope
LED can do weird things, it needs to be a regular bulb but I don't know if anyone tried a resistor in it.
Old Jun 13, 2017 | 04:12 PM
Shawn MacAnanny's Avatar
Shawn MacAnanny
It will also cause your auto converter to randomly unlock. Yeah it can cause issues. I am not sure what resistor you could use. I know on some 4th gen fbodys we would just run a 12v relay on the circuit and the coil added enough resistance to make it work correctly. There's not a great place to put one of those in the 3rd brake like on a truck though.
Old Jun 13, 2017 | 09:50 PM
idt-572's Avatar
idt-572
I have a 6 ohm resister to try, I am going to ohm out the original bulb when I get one and see how much it has.
Old Jun 13, 2017 | 09:51 PM
Shawn MacAnanny
Might have to get that bulb up to temperature first
Old Jun 13, 2017 | 10:26 PM
fordpride's Avatar
fordpride
You can use led but it has to be a high quality SMD LED
SMD LED are for the new Canbus system. They have built in resistors since canbus sends a consistent .05v. With out SMD LED on a newer vehicle the light would constantly stay on
Old Jun 13, 2017 | 10:29 PM
fordpride's Avatar
fordpride
You can see the little resistors, they have 101 on them
Old Jun 14, 2017 | 07:59 AM
78 PEB's Avatar
78 PEB
Not to hijack the original thread but does anyone know if adding cruise to a Powerstroke is as easy as swapping on a cruise steering wheel? I am swapping a column from non tilt to tilt and the tilt column came out of a Powerstroke with cruise.....just curious......
Old Jun 14, 2017 | 05:57 PM
fordpride's Avatar
fordpride
Change the horn pad and make a jumper wire for the plug under the hood that goes to the MC
Old Jun 16, 2017 | 08:42 AM
garrettsf250's Avatar
garrettsf250
if your Cruise control isn't working try checking the speed sensor on the pumpkin of your axel. I went and replaced the speed sensor on mine but it turned out to be the harness of the speed sensor. Also the third brake light was out and caused my transmission to switch in and out of overdrive at high-speed's. I replaced the bulb and the transmission work fine again.
Old Jun 16, 2017 | 11:12 AM
idt-572's Avatar
idt-572
Thanks, I am gone all next week, but I am going to start testing on this problem when I get back.
I sure miss my cruise control.
Old Jun 16, 2017 | 11:14 AM
idt-572's Avatar
idt-572
Thanks for the pic............
Mr. PC
2004 - 2008 F150
May 27, 2015 01:24 PM
pintobobster
1983 - 2012 Ranger & B-Series
Sep 30, 2014 12:04 PM
FX4Marcus
2004 - 2008 F150
Apr 5, 2009 01:10 AM
Flea
Dec 23, 2007 11:38 PM
c96drumm
Mar 28, 2004 10:07 PM
