Need Help
Old Jun 12, 2017 | 10:37 PM
rodneyfischer's Avatar
rodneyfischer
Need Help
1982 f-150 4X4 351w. The cruise control isn't working. I changed the switches on the steering wheel, checked all the wires and hoses, cleaned all of the connections and plug ins, changed the fluid pressure switch and checked the fuse. I tore my dash apart looking for the light bulb that is supposed to come on when the cruise is on, but, I don't think it has one.
Old Jun 13, 2017 | 05:55 AM
Franklin2's Avatar
Franklin2
I believe your cruise is the same as this 86 diagram in this link. Read up on it, lots of things to check that can go wrong and make it not work.
Speed Control - ???Gary's Garagemahal
Old Jun 13, 2017 | 06:55 AM
CountryBumkin's Avatar
CountryBumkin
What is the "fluid pressure switch"?
Perhaps OP is referring to the "Vacuum Dump Valve" (under dash at brake pedal)?
Barnesrr
Modular V10 (6.8l)
13
Mar 3, 2016 06:06 AM
BigE2000
Aug 21, 2011 07:14 PM
Eric H
May 21, 2011 08:12 AM
RobbyMartin
1997 - 2003 F150
13
Nov 23, 2008 11:12 AM
PureGrunt
Apr 5, 2004 06:50 AM
