fittings
Old Jun 13, 2017 | 02:08 PM
Mixer man's Avatar
Mixer man
From the "Should-a could-a" department:
All you needed was some 3/16" copper tubing (remember -3), two 3/16" brass ferrules, and two inverted compression nuts (these look very similar to inverted flare nuts).
So, you could have done it in all copper or steel line for less than the price of two feet of neoprene hose. Something to remember for next time. And tubing looks much cooler than hose when a bender is used.
Old Jun 13, 2017 | 04:48 PM
Ricardo Chambers's Avatar
Ricardo Chambers
I bought 1/4 od copper at Lowes to match the 1/4 id hose.
I figured to make neoprene joints and copper leads.
With ferrules soldered on and hose barbs it will bounce rather vibrate loose.
Safety wire wraps instead of hose clamps,
very Mad Max-ish...
If you anneal the tubing it bends like taffy.
but I shudda did it your way, my way will probably look like it was done by Jethro Bodine.
Old Jun 14, 2017 | 02:00 AM
pineconeford's Avatar
pineconeford
Knuckle Bandage Sales Rep
This thread is very handy to me since I'm about to plumb up my vacuum line and fuel lines. I have the old stock hard steel line to the 226 to use as a bend template and wanted to use copper to pretty it up.
Thanks guys!
Tom
Old Jun 14, 2017 | 07:29 AM
Tedster9's Avatar
Tedster9
Vacuum advance hard lines, a lot of times anyway, will have that narrow vertical "U" or loop. What's the deal with that?
Old Jun 14, 2017 | 11:29 AM
Mixer man's Avatar
Mixer man
Soldering ferrules?
Old Jun 14, 2017 | 01:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1
To accommodate rotation of the distributor when setting advance
Old Jun 14, 2017 | 02:47 PM
Tedster9's Avatar
Tedster9
Yes, it would need some relief I reckon.
bobbytnm
23
Oct 7, 2023 12:16 PM
Old51f3
Jan 21, 2018 10:03 PM
Melody Guzman
Dec 24, 2012 07:43 AM
skidford
Nov 23, 2006 07:10 PM
