No code, major loss in MPG
About the truck...
6.0l w/ 190K miles
bulletproof EGR and oil cooler, ARP studs, PowerMax turbo, Banks exhaust, Edge tuner (currently running towing tune but have same issue with no tune.
I'm pulling a 9K trailer from AZ to MO. Started out getting 13.5 MPG and that is usually what I get when pulling, usually get 17.5 with no trailer. Half way through the trip my MPG went down to 7.5 and EGTs would climb over 1400 pretty consistently (normal EGTs for this load would be 1200). I understand that the high EGTs correspond with the fuel mileage. Other than the fuel/EGT issue, the truck isn't pulling as well as normal and I've experienced about 3 events of sudden severe loss of power but the truck will quickly get back on it, acts like a loss of fuel pressure.
Boost and EBP seems normal, boost has no problem with 25-30 lbs and EBP is a little less than double boost, which I'm thinking is normal so I have eliminated the turbo as an issue.
I replace the fuel filter every 10K mi along with oil (rotella T6).
Coolant and oil temps are ok over heavy load (ECT reading between 205-225, EOT reading between 205-230).
The truck appears to be blowing healthy black smoke.
Other than poor MPG/high EGTs and sudden loss of power, the engine runs fine. I'm at a loss, please help.
About the truck...
6.0l w/ 190K miles
First check for codes
Second, check for something dragging (brake, belt pulley, tensioner, A/C compressor, etc).
Third, check tire pressure
Fourth, check fuel pressure if you suspect it being an issue
The EBP number looks off to me.
What are EBP, MAP, and Baro at KOEO?
RPM............3300.......3000.......2800........2 600........2400
VGTDC#...32-42%...35-45%...36-46%...38-48%....40-50%
VGT % duty cycle:
low idle......73%
high idle.....43%
cruise........55%
light accel ..67%
hard accel ..38%
coast.........57%
• EBP_DES should be 25-35 psi from 3300 to 2400 RPM under full load.
• EBP_G should be within 2 PSI of the EBP_DES.
• MGP should be 22-27 psi from 3300 to 2400 RPM under full load.
No-Load Boost Pressure Test
RPM..........VGTDC#............EBP_G............MG P
Idle...........60-82%............0-6 psi..........0-1 psi
WOT..........30-45%...........4-18 psi........2-9 psi
VGT % duty cycle:
low idle......73%
high idle.....43%
cruise........55%
light accel ..67%
hard accel ..38%
coast.........57%
bismic, so I ran a no-load boost pressure test and everything appears to match up with your above numbers. Something came to light though... called bulletproof and explained the issues. The tech asked me if I was running a PowerMax turbo which I am, he said that's the issue. Bulletproof quit selling the powermax about 3 years back due to similar issues that came about while towing. That's a bummer since this turbo is only about two months old. The turbo works great and adds a ton of juice when around town but isn't sufficient when pulling.
