Fuel tank issue and engine problems
Old Jun 11, 2017 | 08:13 PM
Branawhoo's Avatar
Branawhoo
I bought a 96' F150 with 4.9L i6 automatic. Has 189k on it. I filled up both tanks when I got it and drove until front tank was about 1/4 full then switched to the rear tank. When that was 1/4 full I went to fill up and the front tank wouldn't take any gas. It would start and stop, eventually spilling out so I filled the rear tank and kept driving. I tried again a couple days later and had the same results. I did a lot of reading and figured it's probably a venting problem, but it's strange since I was able to fill up the week before.
Anyways, a couple days later I'm driving on the rear tank and the engine dies when I come to a stop. It cranked up again fine but did it again a couple miles down the road. I switched back to the almost empty front tank and it still would die when I came to a stop. Not every stop, but maybe every 2-3 stops. It also hesitates and "jumps" a little when going about 20-30 mph.
I was checking underneath the truck for anything unusual but couldn't find anything. Lines look clean and the fuel filter looks rather new. I had the front engine cap off and cranked the truck and gas started coming out of the front filler hole. Doesn't do it on the rear tank when it's off. I plan on getting a gauge to check fuel pressure to rule that out, but I'm hoping someone can give me a few ideas on what to check.
Old Jun 12, 2017 | 11:07 AM
94ZR580's Avatar
94ZR580
Sounds like another fuel transfer issue. The front tank won't take any fuel because the the rear tank fuel is returning to the front tank instead of the rear. Research the dual tanks and the switching system.
Old Jun 14, 2017 | 11:50 AM
Branawhoo's Avatar
Branawhoo
I checked the pressure and wasn't getting anything with key in the ignition. I'm guessing it's an electrical thing now. Aside from checking relays, what should I check before having to take the tanks off and get to the pumps?
Old Jun 14, 2017 | 02:25 PM
rla2005's Avatar
rla2005
The front tank has bad check valves in the Fuel Delivery Module. As the rear tank pump is running the fuel is returning to front since the check valve is open. Very common issue. Most likely the open check valve is bleeding off enough pressure to cause the engine to starve for fuel.
As far as your statement of "I checked the pressure and wasn't getting anything with key in the ignition" is concerned did you turn the key from the Off to Run position a few times before/while checking the fuel pressure? FYI..the fuel pump relay is energized for 1-2 seconds when cycling the key. The relay will not fully energize until the engine is running.
Old Jun 14, 2017 | 02:36 PM
Branawhoo's Avatar
Branawhoo
That's good to know about the relay. I did turn the key a few times while checking but I'll give it another shot.
Question: do both pumps turn on when the engine starts or just the one selected?
Old Jun 14, 2017 | 05:16 PM
rla2005's Avatar
rla2005
Only the selected tank's pump is activated via one set of contacts of the switch located on the dash. The other contacts are for the fuel level circuit.
Old Jun 15, 2017 | 03:55 PM
Branawhoo's Avatar
Branawhoo
I rechecked the fuel pressure today and was getting between 40-50 on both tanks with just key turned and when cranked. I let it idle for about 5 minutes and it stayed right at or just under 50 psi. I was hoping it would start to die out and I could check it but I didn't. There's also a pretty noticeable gas smell that's been around since it started doing this. I'm guessing that's consistent with bad valves or venting issues?
Sorry if I'm missing something obvious, I'm just not used to diagnosing truck problems yet. I appreciate all the help so far. After reading other people's problems with fuel pumps on these trucks I'm planning on just replacing the pump/module in the rear tank. Is there anything electrical I should check before trying to deal with the tanks?
Old Jun 15, 2017 | 04:26 PM
Conanski's Avatar
Conanski
That is consistent with the fuel transfer problem, fuel overflows one of both tanks out the fill tube and the gas tank vent system will often get flooded with gas as well.
Based on your description you should be changing the FDM in the front tank since that is the one that is receiving fuel and potentially overflowing.
Old Jun 15, 2017 | 08:42 PM
Branawhoo's Avatar
Branawhoo
Front tank is what I meant. Thanks for the info. I'll update progress
Old Jun 19, 2017 | 04:56 PM
Branawhoo's Avatar
Branawhoo
Not sure if this is relevant to the diagnosis, but when the engine does start to die, the battery gauge dips as well. It actually starts flickering before it sputters and then it dies. Cranks right back up again though. Also I remember the guys at the dealership having to change the OBD1 to OBD2 for emissions testing. The problem with the engine dying didn't start until a few days after that. However the fuel coming out of the front tank fil tube did happen before then.
Old Jun 19, 2017 | 05:05 PM
Benstoked's Avatar
Benstoked
If it's a real '96, it should have come from the factory with obd2, per Federal regs(link).
The issue you describe sounds like a loose/bad ground?
Old Jun 19, 2017 | 05:23 PM
Branawhoo's Avatar
Branawhoo
Checked the grounds and noticed this.
The ground from engine block to firewall was resting against this line and was melting.
Old Jun 25, 2017 | 04:52 PM
thzpcs's Avatar
thzpcs
Well there's your problem!
Old Nov 16, 2017 | 10:33 AM
Branawhoo's Avatar
Branawhoo
Update
i replaced the fuel pump in the front tank with the Spectra pump (I’m aware that everyone hates Spectra, but I’m cheap) and it’s been running great for about 2 weeks. Was having some engine misfires before so I had the spark plugs changed as well. I’m now getting a p0171 code running too lean. The only thing I’ve noticed is that after maybe 10 miles of driving the engine temp will start to rise when idle. As soon as I start driving again it goes back down to or below normal. I’ve also noticed when I have my heat on, it will get cool when idleing and then blow hot again when I start driving.
The battery meter has always been funny since I got the truck and will dip down or tick with the blinker when I’m idleing. It still does this.
I changed the oil yesterday and checked the fuel pressure and I was sitting right at 50 psi on the fthe not tank. Haven’t used the rear tank since I got the front one working. Could I be looking at a vacuum leak somewhere in the air intake? Or possibly fuel pressure stuff?
Old Nov 16, 2017 | 12:50 PM
rla2005's Avatar
rla2005
50 PSI at idle I assume? What about under load?
Phobia16V
36
Jan 18, 2021 04:01 PM
rohls
May 11, 2019 10:37 PM
EgoTrip90
Apr 24, 2015 07:44 AM
Penrider
May 10, 2010 03:02 PM
1994_F150_302M
Sep 30, 2005 04:18 AM
