So last night was the first time I've ever been stranded by a Ford, I know it's crazy. So driving down the road and my truck begins to shudder like it's out of fuel I'm thinking why I just filled up tank reads full. So pull over I've got spark , and fuel pressure so I try to key it runs then immediately dies. Check my fuel filter since I'm new to the truck I bought one on the incase, nothing new starts then dies. So I check pressure again and I have no pressure, dropped the rear tank walked to O'Reillys bought a fuel pump for the rear tank and installed it on the side of the road. Motherf***** starts right up runs all the way home. So my question is do the tanks transfer fuel between both or is it dual fuel pumps. Also should I be waiting for something else to break in reaction to this?
My 89 has three pumps, one in each tank and one on the rail. Mine died running from the rear tank even though I had just filled up. Switching to the front tank and all was good and for now I'm just not using the rear tank.
1990 was the first year for individual high pressure pumps in each tank. Earlier models used low pressure in-tank pumps and a high pressure pump on the frame.
It's for a 1991 but should be very similar to yours.
Jumper pins 2 & 6 on the diagnostic connector under the hood then turn the key to the On position. This will keep the selected fuel tank pump energized. Use a test light to trace out the power to the pump.
