Vacuum issue
Old Jun 11, 2017 | 02:49 PM
62FE4x4's Avatar
62FE4x4
Vacuum issue
I have a 94 F350 with a vacuum issue. When my a/c is on max cool it will not blow out the vent. Regular a/c works fine. The a/c/heater control switch is new. Vacuum pump is new. Vacuum lines at the heater box look ok. Any ideas?
Old Jun 11, 2017 | 03:03 PM
'89F2urd's Avatar
'89F2urd
Do you have a vac line running to your fresh air damper? It's the door that selects outside air for normal ac, and cabin air for max. The actuator is on passenger side near firewall.
Old Jun 11, 2017 | 06:30 PM
62FE4x4's Avatar
62FE4x4
I checked lines again. I missed the actuator completely. It had a vacuum line then went into a wiring harness that fed down into the firewall. Inside the protected loom covering I found a broken vacuum line. Repaired and working properly. Thank you
Old Jun 11, 2017 | 06:45 PM
'89F2urd's Avatar
'89F2urd
That's always the first one to go for some reason, those white lines have no longevity.
a.ibrahim
Dec 14, 2022 01:41 PM
powerstroke7367
Aug 13, 2019 05:31 PM
RESmalley
Feb 14, 2016 10:07 PM
Gman200108
Jun 15, 2015 08:00 AM
Crawler374
Jan 13, 2011 10:48 PM
