How to clean/flush fuel tank full of garbage fuel?
Hey gents,
I went to replace my front fuel pump yesterday and evidently it's been unused for many, many years. The fuel smells like varnish and water, so obviously I need to drain it. But also the pump assembly was missing the float and the filter sock, so they are in there somewhere as well.
Once I drain the tank, how do I go about flushing it/cleaning it? It's a 16gallon or so tank, so I can't use vinegar (at least cost-effectively) like I do on motorcycle tanks.
That or am I just money ahead buying a new tank? I had going from OEM parts to aftermarket when I don't have to.
Oh! And lastly, does anyone know the part number for the vent grommet for the tank? Mine appears to be nothing but crumbling foam.
Thanks very much!
S/F,
-Matt
Thanks very much!
S/F,
-Matt
Hey gents,
Thanks very much!
S/F,
-Matt
Thanks very much!
S/F,
-Matt
Also, there are products you can use to coat the inside of the tank to make it last longer, maybe Eastwood or another company makes a good one.
The front tanks last quite a bit longer than the rear, considering the rear gets more road grime abuse and suffers from more frame flex (straps constantly rubbing). If your front tank is spotless, it's worth cleaning. I've dropped tanks on these to replace pumps where a few weeks later they leaked...so I don't normally go through the trouble dropping them to replace pumps without replacing a 20-30 year old tank in the process.
Thanks fellas. This truck is a Texas truck so there is basically no rust anywhere on it. Aside from the gross stuff inside the whole thing is solid, no exterior rust. I'm going siphon out the junk fuel and see what I'm working with when the new pump assembly comes in. Really hoping that there isn't a bunch of sediment in there, but we'll see!
timothy47129
01-31-2009 05:50 AM
