New oil spec help
Old Jun 11, 2017 | 01:58 PM
Boaterguy's Avatar
Boaterguy
New oil spec help
Hi all, I stumbled on something here in FTE about Fords new oil spec for Powerstrokes. I have been using Rotella T6 since the first change. Apparently Ford does not like the new CK-4 oils in these motors. Another member posted a chart showing the oils that meet spec WSS-M2C171-F1 and the only oil I recognize from the list is Valvoline extreme blue. I cannot find it anywhere at my local retail outlets. Before I double my cost for an oil change, I assume we all are stuck using Motorcraft 5W-40 from the dealer until the rest of the manufacturers can meet Ford's new spec? I couldn't find anything on Shell's website about meeting the new spec.
This is a 2015 Superduty and when it doesn't hvbe my boat behind it, I am hauling around 8000lbs worth of tractor so I tow frequently which is why I have been using synthetic. It's kind of funny that the new oils don't mix with these engines and I never heard about it from Ford but had to "by chance" see it on FTE! I guess what I am asking is, is there any latest info concerning oils that we must still use one from the list?
Old Jun 11, 2017 | 03:31 PM
EO2SeaBee's Avatar
EO2SeaBee
Napa is usually a good spot to find the Valvoline PBE.
Old Jun 11, 2017 | 04:08 PM
System's Avatar
System
Prolocutor
T6 is not yet on the list. NAPA does indeed have the PBE and it's on sale this month for $19.99...
Old Jun 11, 2017 | 05:37 PM
SkiSmuggs's Avatar
SkiSmuggs
Yup, I switched to Valvoline PBX. Need to stop by NAPA to stock up while on sale.
Old Jun 11, 2017 | 05:44 PM
senix's Avatar
senix
You can always run the dino oil for the summer to give shell somemore time to fix the T6
Old Jun 22, 2017 | 08:23 AM
Glittle's Avatar
Glittle
I got a couple cases of Valvoline PBE and the words "rated for CK-4" is not on the bottles in addition to CJ-4. I'm sure it is still on the approved list, right?
Old Jun 22, 2017 | 09:08 AM
System's Avatar
System
Prolocutor
All PBE is approved whether in CK4 or CJ4...
Old Jun 22, 2017 | 11:56 AM
Just Strokin's Avatar
Just Strokin
I got the oil changed in the truck Monday at a Ford Fastlane. The full synthetic 5w40 Motorcraft they stocked at the dealer was still CJ-4 rated oil.
Old Jun 23, 2017 | 02:57 PM
PwerStroke99's Avatar
PwerStroke99
Here is the list, last updated 3 days ago. You have many choices of CK-4 Oils you can use. I have not looked this over, but here it is. These new oils are not going to double our oil change cost.
I run Lubrication Engineers 5W40 in mine.
https://www.fcsdchemicalsandlubrican...SSM2C171F1.pdf
caere
6.7L Power Stroke Diesel
Aug 4, 2024 07:24 PM
krecak
Oct 1, 2017 10:01 AM
mooch91
Jul 23, 2017 10:15 PM
2009kr
Jun 24, 2017 03:58 PM
jetch114
Nov 30, 2006 11:50 AM
