ScanTool 426101 causing network errors
Old Jun 9, 2017 | 05:28 PM
cnm_mike's Avatar
cnm_mike
I recently purchased a Scantool 426101 to use with Forscan and Torque Pro. After several engine starts, the truck (F350 6.7L) started to sputter when put into gear. I would also get weird messages such as " the downhill assist module is missing", well duh, I do not have downhill assist. When I pull out the Scantool, the problem disappears. When I check for error codes, I get a "network error". Based on not hearing of such problems with the Scantool, I am assuming I got a bad one and will return it to Amazon for replacement unless someone has other ideas.
thx,
Mike
Old Jun 9, 2017 | 10:48 PM
wb6anp's Avatar
wb6anp
I have had that issue on both this truck and my f150 when running the obd adapter and torque pro, I am leaning towards it being a torque pro issue, as it has doen that with 2 different adapters. I can leave the scantool plugged in and run forscan lite and never see that problem.
Old Jun 10, 2017 | 08:47 AM
cnm_mike's Avatar
cnm_mike
Thanks, will try the lite and see if the problem goes away.
Old Jun 13, 2017 | 10:56 AM
manowell's Avatar
manowell
Interesting, that matches what I've seen....
Old Jun 14, 2017 | 08:34 AM
cnm_mike's Avatar
cnm_mike
I found this on a Dodge Forum:
"It's the auto negotiation feature. Just set up the vehicle profile to negotiate using iso-15765-4 Can(11 bit 500k) only and the issues should go away."
I changed my setup and have been running fine for the last several days.
Mike
Old Jun 14, 2017 | 08:58 AM
wb6anp's Avatar
wb6anp
the one thing I wanted on torque pro I cant get to work is the dpf% but now I have that on my truck display so its not needed. I also have my coolant and trans temp, the only thing torque would show now is egt.
Old Jun 14, 2017 | 06:00 PM
cnm_mike's Avatar
cnm_mike
I use Torque to watch the Boost numbers vs. idiot gauge. EGTs post turbo and also pre-DPF are interesting to keep an I on. The only think that I really want to keep an eye on is the oil temp. I wish the Forscan guys could get the real numbers to show on top of the idiot gunge like they have for the tranny and water temps.
fabsroman
Dec 1, 2018 03:08 PM
Robo02
May 12, 2017 04:34 PM
djed
Jun 30, 2015 01:36 PM
JuanHuevos
Mar 5, 2015 09:14 AM
Tugly
Apr 28, 2014 06:21 AM
