Problems with Torque Pro
Old May 11, 2017 | 04:44 PM
Robo02's Avatar
Robo02
Trailering
I installed Torque Pro on Samsung Galaxy Tab A, using OBDLINK MX adapter, have run the OBDLink program for six months, no problem, I wanted more information so purchased Torque Pro, it is causing communication problems, multiple error codes, I know I must be doing something wrong. Ideas?
Old May 11, 2017 | 10:06 PM
wb6anp's Avatar
wb6anp
I have had it do that twice on my '17 and several time on my '09 f150, I never was able to say if it was torque pro? or the elm that caused it. it has done it on 2 different adapters. make sure to turn off torque pro before shutting down the truck, it has helped on mine so far. Also hope you can get the DPF% to work I have never been able to get it to work.
Old May 12, 2017 | 05:51 AM
Robo02's Avatar
Robo02
Trailering
Thanks, it has happened three times, all when first started, I will try turning Torque Pro off before shutting down but may need to look for another program.
Old May 12, 2017 | 08:29 AM
BII Plow Truck's Avatar
BII Plow Truck
What are some other programs available?
Old May 12, 2017 | 04:34 PM
Robo02's Avatar
Robo02
Trailering
The readouts available as a download with the OBDLINK are good, just not quite as many as Torque Pro, been using it got six months, never have been able to get transmission temperatures, I know it is available on the dash, just would like all on same display.
HRTKD
Oct 14, 2024 07:06 AM
HKusp
Apr 25, 2018 06:50 AM
bigb56
Mar 16, 2015 08:05 PM
05F250DSL
Oct 28, 2014 12:47 AM
the_auto_tech
Nov 6, 2013 02:23 PM
