Manual Steering Swap
Jun 9, 2017 | 04:11 PM
Will my stock pitman arm of my manual gearbox fit a Saginaw gearbox?
Jun 9, 2017 | 05:51 PM
PS pitman arms are PS-specific. The difference btwn manual and PS pitmans is the head angle... one is less angled that the other. I forget which....
There is a pic comparing the two over at Fordification.
Jun 9, 2017 | 06:33 PM
Quote:
Originally Posted by
HIO Silver
HIO, I just took a look at the Technical articles and it doesn't show the pitman arm. Would it be posted any place else ?
Jun 9, 2017 | 06:40 PM
Jun 9, 2017 | 07:04 PM
HIO Silver
Ok I do see the difference, thank you ! Problem solved, I contacted there person I bought the Saginaw from and he has the pitman arm.
Jun 10, 2017 | 08:24 AM
Jun 10, 2017 | 01:36 PM
Jun 10, 2017 | 01:43 PM
ultraranger
This is a pitman arm from a '75 F100
2WD that had a Saginaw PS gearbox. (D2TA-3590-BA. Cast with "PWR STG F-100-250" on it).
^ D2TZ-3590-B .. Pitman Arm-Use with Ford/Saginaw P/S / Marked:
D2TA-3590-BA / Obsolete
1971 F100/250 2WD
from serial number M00,001; 1972 F100/250 2WD; 1973/79 F100 2WD; 1973/79 F250 2WD
under 8,100 lbs. GVWR; 1975/79 F150 2WD
lauxg
Apr 14, 2018 01:35 PM
shty150
16
Jul 5, 2017 09:59 AM
Bryanblaylock
Sep 30, 2015 07:00 PM
glenn Allen
Oct 12, 2008 09:49 AM
