What does it take?
Old Jun 8, 2017 | 11:24 PM
banned's Avatar
banned
What does it take?
1974 F100 Camper special , front disc brakes, automatic. What does it take to add a power brake booster? Is a different brake pedal required? This truck has a dual master and proportioning valve. Thanks
Old Jun 9, 2017 | 04:56 AM
FMJ.'s Avatar
FMJ.
I believe an F350 booster will fit, but hopefully someone will confirm what year booster to use.
I read recently here that there are about a million different pedals !!
You may or may not get away with the one you have.
I modified mine very slightly, and retained the correct pedal ratio.
I recently removed the brackets that hold the booster 5 miles away from the firewall, modified the mounting arrangements, fitted the booster directly to the firewall, fitted a 1995 Ford Explorer MC, and have been smiling like an idiot ever since.
Mine is also an auto, so luckily the absence of the clutch MC allowed for the firewall direct fitment.
The pics below are just to give you an idea.
Old Jun 9, 2017 | 11:56 AM
banned's Avatar
banned
Thank you for the response. I added a booster to another car and learned that the pedal ratio was not correct. I suspect its the same here.
Old Jun 9, 2017 | 09:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by banned
1974 F100 not Camper Special, front disc brakes, automatic. What does it take to add a power brake booster?
Yes.
1973/79 F100 2WD: Manual disc brakes were standard equipment, power disc brakes were optional.
D3TZ-2455-A .. Brake Pedal-Use with Power Disc Brakes / Marked: D3TA-2455-AA / Obsolete
1973/74 F100 2WD; 1975/76 F100 2WD without Speed Control; 1975/76 F150 2WD without Speed Control.
1973/74 F250 2WD with single piston caliper disc brakes; 1975/76 F250 2WD with single piston caliper disc brakes without Speed Control.
1973/79 F100/350: TWENTY TWO different brake pedals, NINETEEN different master cylinders, SEVENTEEN different P/B boosters, SEVEN different clutch pedals, I kid you not!
wiltshire46
Oct 6, 2015 06:19 PM
Javier Castro
May 16, 2015 02:36 PM
Smitty's65F100
Sep 17, 2012 02:26 AM
SeaBeeCm1
Mar 1, 2012 03:07 PM
mr_ranger-79
Dec 19, 2011 05:18 PM
