If I turn the signals on after the truck's sat awhile, they will not work. If I play with the signal for awhile, they will work for a long time, and then do it again.
I almost think the contacts are getting dirty.
Would I need to purchase a new multi-function switch or be able to clean the one I have?
Also, I've seen a few posts that mention to look at a relay for problems before replacing the switch. I've never heard of this relay, so where is it? Is it testable?
