oily air filter
Old Sep 4, 2003 | 10:58 AM
jwdenney2's Avatar
jwdenney2
oily air filter
My crankcase air filter is always soaked with oil when I replace it (every 3000 miles!), even to the point that the air filter that sits on top of it gets a big oil spot. What causes this and how can I fix it?
Old Sep 4, 2003 | 11:26 AM
dbuck50's Avatar
dbuck50
oily air filter
either a plugged/defective pcv valve (replace), or you have bad or broken rings causing blowby. If it is not the PCV try doing a compression test to see what you are getting in each cylinder. One might be substantially off from the others.
Old Sep 4, 2003 | 01:11 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
oily air filter
I second, inadequate crankcase ventilation or excessive blowby.
