Help please. Fuse issue.
Old Jun 8, 2017 | 07:00 PM
Equinechel's Avatar
Equinechel
Hi, I am new and have had my baby (2002 excursion diesel) forever. We just got a new camper. It seems that when put in reverse we keep blowing the #38. Any ideas would be amazing. Thank you. Chel
Old Jun 9, 2017 | 07:01 AM
JayTheCPA's Avatar
JayTheCPA
Am presuming this is while connecting to the 7 pin plug and not the 4 pin plug . . .
If the #38 fuse is the same as the pickup ('Trailer tow park lamps and backup lamps'), will need to do the basics of troubleshooting whether it is the Ex's connection, the trailer's plug, or wiring in the trailer.
If possible, a quick check to isolate the Ex is to hook up to another known good trailer with backup lights. Having a test harness / plug is also useful.
If the Ex is good and the new-to-you trailer was bought through a dealer, consider taking it back for them to troubleshoot the trailer and make it right.
If the new-to-you trailer was bought from an individual, then naturally all of the troubleshooting is on you. From this point, consider focusing on its plug and on the rear brake / backup light fixtures (especially the backup bulbs and base).
If the trailer does not have backup lights, my vote is to just focus on the plug as the starting point.
Old Jun 9, 2017 | 07:18 AM
Chuck's First Ford's Avatar
Chuck's First Ford
a 7 pin plug tester (like $12) or a 12 volt test light...
most trailers do not have reverse lights.. but a few do..
if the trailer is Brand New... return it to dealer for warranty fix.
Old Jun 9, 2017 | 10:47 AM
JayTheCPA's Avatar
JayTheCPA
Another possible focus area is if the trailer has surge brakes. In that case the switch that disables the brakes when backing uses the backup light wire. So that is another possible area to look. (Again, if the trailer has surge brakes.)
Old Jun 9, 2017 | 02:01 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Did ya get it fixed???
old farm truck
All Things Towing
26
Sep 2, 2017 08:59 AM
oldrifleman
2009 - 2014 F150
Apr 28, 2015 12:17 AM
Gerby Dutchy
2009 - 2014 F150
Mar 20, 2015 04:18 PM
BassFantasizer
Aug 21, 2013 12:42 PM
Mark T-TB
Oct 5, 2011 03:52 PM
