Towing light issue
Old Aug 18, 2013 | 06:49 PM
BassFantasizer's Avatar
BassFantasizer
Towing light issue
The tail lights on my trailer don't work when it's hooked up to the Ex.
All of the other trailer lights work fine, just not the tail lights. I've verified that there's no power on that circuit at the plug.
Anyone seen this before or know where to start looking?
Thanks,
~Bass
Old Aug 18, 2013 | 08:54 PM
Stebs's Avatar
Stebs
Thanks,
~Bass
Check all your fuses. There are several for the trailer connection... Brakes, left turn, right turn, running lights, battery charge, and possibly reverse light...
Edit: on my 02, it appears fuse 38 is for "trailer tow park lamps and backup lamps"
Old Aug 18, 2013 | 08:58 PM
JWC 3's Avatar
JWC 3
X2 on fuse ck . See that a lot . Also ck the truck plug for loose wires , bad connections ect .
Old Aug 18, 2013 | 11:23 PM
EXv10's Avatar
EXv10
Fuses, then take a little sharp pointed light tester and stick it in the trailer plug to check each circuit one at a time and match them up to the trailer circuits. You will need someone (with some patience) to work the controls up front. I labeled all mine with a marking pen; LB RB ST TA GR etc.
Old Aug 19, 2013 | 01:22 AM
Stebs's Avatar
Stebs
I guess I'm having a hard time following this... Ta? Gr?
Old Aug 19, 2013 | 07:13 AM
BassFantasizer
LB RB ST TA GR - Left Blinker, Right Blinker, Stop, Tail, Ground.
I know it's in the Ex, and that the fuses are good. Guess I'm going to have to start tracing a wiring harness issue.
~Bass
Old Aug 19, 2013 | 09:43 AM
EXv10's Avatar
EXv10
Short for taillight ground left blinker etc
Old Aug 19, 2013 | 04:52 PM
Stebs's Avatar
Stebs
I follow ya now... I figured out the first 3 but the last 2 threw me off.... They're actually already labeled on the spring loaded cover that protects the 7 pin plug when its not in use...
Old Aug 19, 2013 | 11:22 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Bass, I had the same issue when I bought mine. Went to tow a trailer...and no tail lights. I had blinker on one side and one stop lamp. It was three of the fuses under the hood blown. Right next to the brake master cylinder. Not sure if the 00 is set up the same way...
Old Aug 19, 2013 | 11:59 PM
EXv10's Avatar
EXv10
Fuses under dash and under hood but the OP probably already knows that.
Old Aug 20, 2013 | 05:13 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
It wouldn't hurt to add an extra ground from the harness on the Ex to the frame and an extra ground on the trailer side too. Most of the time it seems like a ground issue in these cases.
Another thing to check is the pigtail on the truck, unplug it and look for corrosion on both sides.
Old Aug 21, 2013 | 08:29 AM
Scuds ion's Avatar
Scuds ion
Yep, me too.
Just found same issue on my '05...
Fuse is fine,(fuse 38) but no power at the 7 pin plug.
Probably a broken wire.........
look up Bargman or other company to find a diagram of the 7 pin.
That will help with tracking........
I am doing a little rigging for this weekend's tow. Fix it next week.
Old Aug 21, 2013 | 08:54 AM
BassFantasizer
Last night I learned that the Ex was previously tagged in the right rear. There were a couple of indications that something wasn't quite right, but the paint match was excellent so I didn't think about it. Then I saw something in the right rear wheel well and realized that the repair was sub-standard. Now I'm wondering if the trailer light issue and the rear-end vibration are due to getting hit???
Old Aug 21, 2013 | 12:42 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Certainly could be. Mine was rear ended a month ago, and the wiring harnesses behind the bumper were crushed.
gbkeith
Apr 16, 2018 08:57 PM
mrblonde108
All Things Towing
Dec 21, 2011 01:33 AM
2kcrewcab
6.4L Power Stroke Diesel
13
Apr 7, 2011 06:04 AM
lilpro
All Things Towing
Jul 6, 2009 01:35 AM
jake00
Jun 11, 2006 11:25 PM
