Any suggestions???
Old Jun 8, 2017 | 01:12 PM
SteelHorse4x4's Avatar
SteelHorse4x4
Any suggestions???
Hey guys, haven't had a chance to dig into it yet. Driving down the road this morning, truck just died. Had it towed home. Just got home. It has spark, both fuel pumps run constant, no start. Fuel pressure regulator? Probably won't be able to mess with until the weekend. Thank God I have 6 trucks, lol. Wife's chemo appointment this afternoon so I've got some time for suggestions. Thanks in advance.
1994 F150 5.8 e4od Mass Air Flow conversion.
Old Jun 8, 2017 | 01:29 PM
crunky944's Avatar
crunky944
You need to get a fuel pressure tester on there. I've been going through issues with the dual tank setup on my truck. Both of my pumps would run but were not able to supply enough pressure to the fuel rail to make it run right.
If you have a Harbor Freight near you they have a $20 fuel pump test kit, or Autozone will rent you one for $150 deposit. The Autozone one is much nicer and I would recommend it over the HF one.
Do you have any fuel transfer issues? My problem turned out to be bad check valves in my FDMs. Most of my fuel pressure was bleeding out into the opposite tank instead of making it to the fuel rail.
Old Jun 8, 2017 | 03:34 PM
Glenn54's Avatar
Glenn54
I'm no help with your truck problem but I said a prayer for your wife. Best of luck.
Old Jun 8, 2017 | 03:56 PM
rla2005's Avatar
rla2005
I assume the "both fuel pumps run constant" means the selected pump run constant and not both regardless of which tank is selected?
A constantly running fuel pump when moving the key from Off to Run is typically a failed computer symptom.
Old Jun 8, 2017 | 04:37 PM
SteelHorse4x4
Yes. Did manage to get a pressure reading. Approximately 38 psi, from either pump. And yes, selected pump. Hopefully this wknd I'll be able to pull computer and also check pins and sockets​ in connector to computer. A couple times over the past few weeks it died out of the blue, always restarted. Ran codes, nothing out of ordinary, ie pass. Being intermittent at that time made it difficult to nail anything down. Now that it's constant, I should be able to get it back to being reliable.
Old Jun 8, 2017 | 05:22 PM
rla2005's Avatar
rla2005
Open up the computer and look for leaking capacitors. Very common for this issue to happen.
Old Jun 9, 2017 | 07:42 AM
subford's Avatar
subford
2X^^
Yes the clock is not running in in the PCM Computer.
Old Jun 12, 2017 | 08:56 AM
SteelHorse4x4
Originally Posted by subford
2X^^
Hey subford. I've pulled the computer. Only see one cap that could "possibly" be leaking. Does this look like a leak
Old Jun 12, 2017 | 09:56 AM
subford's Avatar
subford
Yes it does look like it is leaking. The cap is right by the clocks crystal.
Old Jun 12, 2017 | 10:32 AM
SteelHorse4x4
thank you sir.
Old Jun 16, 2017 | 04:57 PM
SteelHorse4x4
Thank you subford. .17 cent capacitor, runs good again.
Hazmat 67
13
Dec 2, 2019 01:32 PM
91chevywt
Mar 4, 2011 04:48 PM
dr strangelove
Sep 9, 2010 04:13 PM
szpieleusa
6.4L Power Stroke Diesel
Mar 30, 2009 08:26 AM
ShadeTree49
Dec 18, 2004 08:06 PM
