plastic clip for door lock
Old Jun 7, 2017 | 11:28 AM
N2S3's Avatar
N2S3
tried to remove the old door lock, where no key is found.
had seen a YT, but the plastic clip bursted into million parts, 40 years old...
Is there a source to get one or better two new ones? what might be the part#?
the manual speak about "the clip"...
Old Jun 7, 2017 | 01:29 PM
JD Q's Avatar
JD Q
I purchased an assortment from Autozone, over the counter. Their website did not show it, however I found some on advanced auto parts: https://shop.advanceautoparts.com/p/...VVtfgodausBFw#
measure the rod diameter to compare.
LMC has: Retainer, door latch rod 40-1362
Hope this helps
Old Jun 7, 2017 | 03:35 PM
HoustonDave's Avatar
HoustonDave
Once did a field repair on Dad's Cutlass using a twist-tie in place of the broken plastic part....lasted till the car was totalled 4 years later. Replacement clips are available in most parts stores in the Help section.
Old Jun 7, 2017 | 03:52 PM
jaleus's Avatar
jaleus
Another chain comparable to the two mentioned has the assortment pack as well, had to buy 8 or 10 of all different sizes to get one that was close and it only lasted a couple months on my tailgate. Ordered a couple from Dennis Carpenter that are said to be the proper size.
Old Jun 7, 2017 | 05:16 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on most auto parts stores carry it in the "help" section and yes you normally have to buy an assortment pack.
JBG, DC or MACS should carry them.
Part # 21952 in the PDF diagram?
File Type: pdf
Old Jun 7, 2017 | 05:23 PM
burnthelight88's Avatar
burnthelight88
Dennis Carpenter or the "help" section at advance auto parts. Not a big fan of theirs, but their help section is key.
Old Jun 7, 2017 | 11:22 PM
PapaBearYuma's Avatar
PapaBearYuma
I bought the clips for the tailgate from Bronco Graveyard, and found out they also fit the door lock mechanism.
Old Jun 7, 2017 | 11:31 PM
84espy's Avatar
84espy
You may also want to look in yards like Pick N Pull. Most of the car companies used the same clips across the board for both cars and trucks.
Old Jun 8, 2017 | 12:21 AM
N2S3's Avatar
N2S3
Thank you for your helpful advices. Yes, Part#21952 seems correct.
Old Jun 8, 2017 | 01:12 PM
beartracks's Avatar
beartracks
ClipsAndFasteners.com - Automotive Retainers,Clips and Fasteners
Motate455
Mar 5, 2019 03:32 PM
Robert S
Aug 8, 2018 09:30 PM
explorerjwd
Aug 8, 2010 02:42 PM
chrismartinez0
May 24, 2010 04:55 PM
ford4life69
Apr 5, 2010 10:37 AM
