Oil Seal
Old Jun 8, 2017 | 02:24 PM
jakeharp's Avatar
jakeharp
Oil Seal
So spawning from this thread
https://www.ford-trucks.com/forums/1...e-install.html
And onto the inner hub oil seals (4250's), whats the preferred method for you guys to driving these in ? I tried last night to tap one in gently with a rubber hammer, but there was a tight spot that I just couldn't get around to even out the seal , any tricks or whazoo methods ? The back side of the bearing driver disc dosent seem like an option due to the rubber lip that would be smashed ?
Old Jun 8, 2017 | 04:22 PM
FMJ.'s Avatar
FMJ.
Use the tools you bought as shown in post 21, but make sure to use one wide enough to rest on the metal lip.
It shouldn't affect the rubber lip at all.
Line up the seal over the hub and +/-3 taps of a normal hammer should do it.
A rubber hammer is too soft.
Then, wipe the rubber seal, and the surface the seal will rest on, with diff oil, or do that just before you refit the hub.
Good luck !
Old Jun 8, 2017 | 04:53 PM
jakeharp's Avatar
jakeharp
Cool
Thanks man, once again im overthinking this....... You would think im operating a life saving procedure on the first born........ Just want to get this right the first time with no leaks ...... Really just want to drive my damn truck again !
Old Jun 8, 2017 | 05:15 PM
FMJ.'s Avatar
FMJ.
You're not overthinking at all !
You're being cautious coz it's your first time.
It gets easier with practice.
If worst comes to worst, and you f$$k it up, fine, just get another one.
ArdWrknTrk
Sep 11, 2011 10:48 AM
bill davis
Large Truck
Oct 8, 2010 04:16 PM
69ford99
1978 - 1996 Big Bronco
Nov 22, 2006 01:28 PM
RhinoScores
Sep 8, 2006 08:17 PM
