Small oil leak
Old Jun 7, 2017 | 08:54 AM
MTP55's Avatar
MTP55
Small oil leak
I did my oil change this morning and found this. I have read that rear main seal failures are uncommon on the 2000 7.3. I went ahead and checked HPOP, turbo, and other places up top. There's dirt mixed with maybe a tad bit of oil but mostly fuel that got there from the drain valve leak. Pretty well dry. I didn't see any leak around d the oil pan but maybe I missed it. Does it look like a major concern?
Old Jun 7, 2017 | 11:19 AM
Stewart_H's Avatar
Stewart_H
If your fuel bowl had a recent leak you just fixed, but didn't clean out the engine valley, then that's more than likely what's keeping that area wet.
Check and clean out your valley with brake cleaner and down below and then see if the leak continues.
Stewart
Old Jun 7, 2017 | 11:23 AM
MTP55's Avatar
MTP55
Thanks, will do as soon as we are done planting soybeans.
nick7.3
Sep 6, 2010 03:39 PM
countrykid_86
Aug 4, 2009 05:51 PM
150ford
Apr 13, 2009 12:22 AM
pushingxthexedge
Feb 16, 2008 06:19 PM
profro
Jan 29, 2007 08:17 PM
