multifunction switch?
Old Sep 4, 2003 | 10:57 AM
mahause's Avatar
mahause
Question multifunction switch?
I have a 98 Expedition EB. When I go from high beams to low beams I lose lights all together. I notice when I move it slightly forward the lights come back on. I believe this is caused by the multifunction switch. Has anyone changed it?
Old Sep 4, 2003 | 11:01 AM
stepman's Avatar
stepman
Not on an explorer but, on a windstar its not that hard. Just have to pull the column covers and there are a couple of screws holding it on. Hardest part is trying to unplug the wires with the limited space.
Old Sep 4, 2003 | 11:45 AM
Rtpjunior's Avatar
Rtpjunior
The switch is not too bad to pull, hust a little tricky. Pull the lower dash cover off, and look underneath the switch. You will see a small opening. Insert a small pick or similar and slide the release over. The switch is held in by a spring-loaded tab, and can only be released this way.
Old Sep 5, 2003 | 06:46 AM
DIV16's Avatar
DIV16
Remember to disconnect your battery so that you don't accidentally blow the airbag.
Old Sep 8, 2003 | 10:42 AM
mahause's Avatar
mahause
Does the multifunction switch also control the rear windshield wiper? That is also working intermitently.
Old Sep 10, 2003 | 09:48 PM
2003EXPY's Avatar
2003EXPY
The MFS controls the rear washer and wiper also.Fords MFS's are their way of garranteeing future profits for their parts division. I had my 98 Expy's replaced right before the warranty expired,and when I bought my 91 Grand Marquis and 96 Cougar I had the dealer replace them before I'd buy the cars as they were intermittantly bad . My 03 Expy's got 28 months left on warranty so we'll see how long this one lasts.
Old Sep 10, 2003 | 11:36 PM
tsdrallyer's Avatar
tsdrallyer
I had to replace the MFS on my '97 twice: at 25K miles and 50K miles. Since then it's worked perfectly with no problems. Now at 112K miles. Ford had a bad supplier I guess.
Old Sep 11, 2003 | 10:30 AM
mahause's Avatar
mahause
Post multifunction switch?
Thanks. I contacted my local ford dealer since I found a Technical Service bulletin for the MFS on alldata.com. This is being campaigned. He said if it goes through they will reimburse the cost of fixing it. I won't hold my breath though.
blaze1214
Dec 19, 2014 08:55 PM
4INer
Feb 27, 2014 07:27 AM
DiamondCrown1971
May 30, 2013 02:42 PM
Snuggyworm
Jan 17, 2012 09:25 PM
jjdoyle
Jan 3, 2011 08:38 AM
