keyless entry
Old Aug 21, 2003 | 09:13 AM
tplanz's Avatar
tplanz
keyless entry
I have a 2000 EB Expedition and I'm trying to re-program the code for keyless entry. I've found the factory code but when I try to enter it, nothing happens. The keypad doesn't illuminate. Is there a fuse or something for this? Does anyone have any suggestions? Thanks in advance.
Old Aug 21, 2003 | 09:37 AM
dalejarrettfan's Avatar
dalejarrettfan
keyless entry
when you hit the far right two keys simultaneously do you here the doors try to lock?
if you don't chances are that the key pad is dead....pretty sure all that's in there are thin copper contact sheets. .......had it replaced on my '99 xlt because of this issue........seems like ford likes those thin sheets of copper (cheap lightweight)'93 f-150 multi-function turn signal had this in the wiper part and wore out in 50,000 miles
Old Sep 7, 2003 | 01:13 PM
KeithE524's Avatar
KeithE524
keyless entry
I have a '99 Expy Eddie Bauer that I just purchased. I think that my key pad is dead, too. I can't even get the 7/8 and 9/0 to lock the door. I know how to take the key pad off, since I have already been inside the door to check it out. Any idea how much a new one is? I did see one on eBay a couple of weeks ago.
Keith
Old Sep 7, 2003 | 05:32 PM
rclarke's Avatar
rclarke
keyless entry
Its kind of unusual for all the switches in the keypad to be bad at the same time. If the keypad doesn't light up when a button is pushed I would do a little checking to make sure there is power to the rap module and everything is plugged in.
Old Sep 7, 2003 | 10:26 PM
KeithE524's Avatar
KeithE524
keyless entry
I just checked my keypad...it lights up when I press the 1/2 key and I noticed that there is no light around the 9/0 key. Is it true that the keypad will light and the interior lights will come on when the first correct key in the sequence is pressed? I ask because I mentioned that they will only light when I press the 1/2 key and my factory code (according to what's printed on the RAP) begins with a 5. I have not gone under the dash to check the wiring at the RAP yet.
Keith
Old Sep 7, 2003 | 11:41 PM
PaulC's Avatar
PaulC
keyless entry
I wonder if there is a programming sequence to enable or disable the keypad?
Old Sep 8, 2003 | 03:25 PM
rclarke's Avatar
rclarke
keyless entry
If at least one button causes the keypad to light the module has power and it is likely the keypad is the problem.
I am quite sure there is no way to disable the keypad.
Old Sep 9, 2003 | 01:28 PM
tplanz's Avatar
tplanz
keyless entry
Where is the RAP module located?
Old Sep 9, 2003 | 02:22 PM
KeithE524's Avatar
KeithE524
keyless entry
The RAP Module (Remote Anti-Theft Personality) is located under the dash, above the brake and emergency brake pedals.
Keith
Old Sep 9, 2003 | 02:26 PM
tplanz's Avatar
tplanz
keyless entry
Does it have any special markings, colors, etc...
Old Sep 9, 2003 | 02:36 PM
PaulC's Avatar
PaulC
keyless entry
It has a sticker that provides the factory-set combination for the keypad.
Old Sep 9, 2003 | 02:47 PM
tplanz's Avatar
tplanz
keyless entry
Thanks. I'll check it out.
Old Sep 11, 2003 | 01:50 PM
KeithE524's Avatar
KeithE524
keyless entry
<b>UPDATE</b>
I opened my door panel and removed my keypad to check continuity between the keys and ground. I was having trouble so I opened up the keypad. <b>CORROSION EVERYWHERE</b>.
I scraped off the corrosion and was able to lock and unlock the doors using the factory code. I will need to buy another keypad at some point, but I am satisfied that I found the problem.
Keith
