Hey just getting around to getting this done on the beast. Just want to check if this is the correct part and if I should be getting anything else to change the front bearings. Thanks
What is the difference if anyone knows besides the price. Just looked at rock auto and there is a few different ones available. the timken ones have fine thread and coarse thread is there a difference for my truck? They also list a OEM one that is less than Auto nation. I do plow with the truck and would like to get the best ones available that we can still use the auto 4wd. Thanks
Reason: add a question
just ordered two of these 3C3Z.1104.A from rock auto for 238.79 a piece plus 20 for shipping. They were actually less than auto-nation for the same oem hub. Got the seals from guzzlers for the auto lock part last week. Gonna try and tackle this over the weekend. Should I be replacing anything else while I have this off? thanks
Reason: add question
Loaded question, LOL
Check the u joints, replace if required
ESOF seals, check
Outer axle seal for sure
Need brakes? Now's the time.
Then buy the timken with the threads that match your Ex.
