Engine Hoist Too Short
Old Jun 6, 2017 | 01:34 AM
520SC's Avatar
520SC
We're replacing a 460 engine with a 502. Today, we bolted the engine load leveler onto the engine, expecting to lift the 460 out of the engine compartment. Problem is, the brand new 2-ton engine hoist i bought at Auto Zone is too short to reach the load leveler from the front, even with the boom set at the 1/2 ton (longest) position. I suppose I can do one of three things: 1) attempt to lift the engine out from the side, or 2) rent a bigger (longer) engine hoist, or 3) hire a company to remove the engine using a crane truck, a $160/hour house call, with a four hour minimum. Needless to say, if I go with option 3 and then transfer parts from the 460 to the new engine (a one-day job, at least), I'll have to call them back here to install the new engine ($1280 in total).
Has anyone ever lifted an engine out from the side?
Old Jun 6, 2017 | 11:25 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
What kind of truck is it? Usually it's the height that's the problem.
Old Jun 6, 2017 | 05:52 PM
Conanski's Avatar
Conanski
What is in the way.. is there a big winch bumper on the truck or something? If so take it off.. that has got to be a better solution than spending all that money.
Old Jun 6, 2017 | 11:14 PM
85e150's Avatar
85e150
Serving suggestion IF height is your issue: Remove front wheels, lower it as far as you can without resting it on the brakes.
Old Jun 8, 2017 | 11:08 AM
EagleFreek's Avatar
EagleFreek
If you can't lower the truck enough you can either try to rent, borrow, build or buy an A Frame gantry hoist. Another option is to rent a forklift for a day from an equipment rental place if you can't find a large enough engine hoist.
Old Jul 7, 2017 | 11:32 AM
speedfreak78's Avatar
speedfreak78
Remove wheels, If its 4wd, remove shocks and use HD ratchet straps to compress the axle to the bump stops, put truck on ground, blocks of wood under frame to keep rotors of the ground. Those 2 things should drop the truck a good foot or more.
Old Jul 21, 2017 | 11:52 PM
bbf385's Avatar
bbf385
I'd take the front clip off before paying 160/hr. If you take it off in one piece it's not that bad.
barstart
Oct 24, 2011 03:41 PM
Rick Wallace
44
Jul 16, 2010 05:01 AM
etucker
Jan 8, 2007 01:07 PM
etucker
Utah Chapter
Aug 28, 2006 10:58 AM
Rocking M
Garage & Workshop
28
Jan 17, 2003 09:47 AM
