1980 F100 Vintage Air install
Has anyone here installed a Vintage Air or any of the other aftermarket air conditioning kits into a 1980 to 86 F series?
I want to install air conditioning into my 1980 F100 Custom, I haven't been able to find any manufacturer that makes a specific kit for it or any info on what they installed from anyone that has done it before.
Thanks
Thanks
Welcome to FTE!
I haven't done it yet, but I do plan to install a compressor from Vintage Air as well as their hoses. I don't know if they make a kit, per se, but when I talked with them they sure knew what they were talking about and I would think they can sell you all of the parts needed.
What after market AC?
So I did not need to swap out the fire wall to have AC
I know for v8 motors you can get the brackets, pulleys and compressors just about any where, not so for the 300 six.
Now I have not looked into the after market AC, I know they make a full replacement system (heat/AC) do they also make an under dash unit?
Dave ----
Dave ----
Welcome to the forum, Amac35! Open the provided link and go to post #117. A fellow forum member [fljab] has purchased components from Nostalgic AC in Ocala, FL.
https://www.ford-trucks.com/forums/1...florida-8.html
Ouch is right! There is an earlier version of compressor mount and it goes basically in the same position, but a bit lower down. I'd do some quality junkyard crawling and look for either version.
Another option which would be easier to source would be the '87 up setup, but you'd need everything as you would have to hook up all your other accessories to it including using the specific water pump (reverse rotation?).
Now the brackets will not work for you from what I hear from someone doing a V belt to serpent belt swap.
Dave - - - -
I think the big issue is finding the right unit that will work under the dash. I was hoping there was something out there in the aftermarket for a complete system that someone had already done.
These links to ebay offerings might provide some "starting" information:
Slim Line Under Dash Heat Cool & Defrost System Air Conditioning Vintage Air | eBay
Vintage Air Mark IV Steel & Chrome Under Dash Air Conditioning Evaporator Kit AC
Under Dash Air Conditioning System | eBay
