Sponsored by: Real Truck
Trailer ball bumper plug
Old Jun 5, 2017 | 09:25 AM
WWR's Avatar
WWR
It's not NEARLY as much fun as it sounds, I know
Anyway I recently bought an '11 F350. As is common (I've come to find) the rear bumper cover was MANGLED from a PO backing into a trailer tongue. Even the steel plate under the cover had been curled a bit and it was all visible through the missing trailer ball hole plug which just kinda bugged me.
So I removed the cover and straightened out the steel plate as best I could.
Then I grabbed the bumper cover from my old '08 which is in much better shape.
The '08 bumper had a hole for a trailer ball and the accompanying plug - shown upside down in the photo.
The '11 bumper doesn't have a way for a trailer ball to fit even if you wanted to drill a hole, so the plastic plug wouldn't drop in.
So I grabbed some 2.5" Al and chucked it up. I turned a lip about 2.170" by .070" high to drop into the 2 3/16" hole in the bumper cover, then drilled a 1/4" hole in the center. I parted it off about .140" OAH. Dropped it into place, drilled and tapped a 1/4-20 hole in the bumper steel plate and anchored w a SS button head screw (c-sunk flat head would be more trick but I used what I had at 9pm)
Supercab
13
Mar 4, 2013 06:47 AM
weberjaw
Oct 30, 2012 08:38 PM
1972RedNeck
Feb 15, 2012 12:29 AM
blueheron
6.7L Power Stroke Diesel
Jan 3, 2011 06:18 PM
Fat Ford Boy
Missouri Chapter
Jan 16, 2004 02:05 PM
