Gas/mods
Old Jun 5, 2017 | 12:11 AM
BustedLariat's Avatar
BustedLariat
Unhappy Gas/mods
I have a 1986 f250 XLT Lariat, with a 351w and 4bbl holley racing carb. stock exhaust manifolds that run into a 2.5in true duel exhaust (without a cat) with an X pipe and a 24in thrush glasspack off each one. Running with the stock 3.55 gearing, but with 33x12.5x16in tires. And im currently pushing 6.5-7mpg. 8 if im cruising at 55mph. Any tips for increasing MPG on it? cause running 7mpg with duel 20gal fuel cells hurts.
Thanks guys
Old Jun 7, 2017 | 11:50 AM
FuzzFace2's Avatar
FuzzFace2
Little late but welcome to FTE
First have to ask how did you come up with the 6-8 MPG @ 55 MPH reading?
You are running 33" tall tires and I bet the speedo is off so the MPH and distance will be off too.
I would say you need to get your measurements right before you can do MPG.
Dave ----
ps: that "racing carb" cant be helping either
Old Jun 7, 2017 | 02:23 PM
1986F150six's Avatar
1986F150six
Check tire air pressure; make certain the choke is opening fully; check the timing; how long since a tune up? Are you carrying extra weight in the bed?
Oh, yeah, welcome to the forum!
Old Jun 7, 2017 | 03:20 PM
CountryBumkin's Avatar
CountryBumkin
^^^^^ racing = poor gas mileage.
Seriously, the performance carbs are jetted richer, have larger accl pump shots, and the power valve opens sooner - that's what makes them perform better than the economy carbs.
Old Jun 8, 2017 | 07:38 AM
Gary Lewis's Avatar
Gary Lewis
You need to decide if you want power or economy - you can't have both. You didn't say what transmission you have, but a C6 auto is very poor for MPG. And a Holley carb adds to that, and especially a big one that is probably a double-pumper. Keep it if you want power, but if you want reasonable economy swap it for an Edelbrock 1406. It'll be jetted right for the 351 out of the box and you'll have better part-throttle response as well as much better MPG.
And, welcome to FTE!
Old Jun 8, 2017 | 07:22 PM
maytag906's Avatar
maytag906
What makes it a "racing" carb?
Old Jun 9, 2017 | 06:27 AM
FuzzFace2's Avatar
FuzzFace2
Holley has an HP series carb.
The early one did not have a choke plate, shaft, etc. But guess you could add one if you wanted as the choke horn was still there.
The ones now Holley removes the choke horn for better flow so nothing to put the shaft thru.
IIRC I have 1 of each for my drag car.
Dave - - - -
tpvegas
Feb 28, 2015 03:17 PM
BRay09
36
Nov 8, 2008 02:05 AM
Nick_F150
29
Jan 13, 2007 01:34 PM
cjbronco
Sep 9, 2005 11:59 AM
mgm415
Feb 28, 2002 09:09 PM
