help with a carberater
Old Feb 27, 2015 | 08:43 PM
tpvegas's Avatar
tpvegas
I have a question on fuel mileage I have an 81 f 250 with a 351 M Holley 600 carburetor and I'm getting four miles to the gallon any help would be appreciated
Old Feb 27, 2015 | 08:46 PM
ctubutis's Avatar
ctubutis
What transmission? Where in the country are you located?
Old Feb 27, 2015 | 08:47 PM
tpvegas's Avatar
tpvegas
T18 transmission las vegas
Old Feb 27, 2015 | 09:44 PM
Gary Lewis's Avatar
Gary Lewis
You probably have a blown power valve. That will kill gas mileage on a Holley. As will a stuck-on choke - on any carb.
But, we really need to know a whole lot more about your truck. Are you running huge tires? How fast do you drive when getting 4 MPG? Have you changed anything just before the MPG went south? Or, has the MPG ever been better?
Old Feb 28, 2015 | 01:45 AM
Trackerrrr's Avatar
Trackerrrr
I live in Henderson and get 8 mpg with my dually. Is your speedo accurate? If it's running slow your mpg calculations will be off.
Old Feb 28, 2015 | 02:00 PM
tpvegas's Avatar
tpvegas
I have stock 16 on my truck what would happen if I get a plug for the power valve I drive 65 on the free way
Old Feb 28, 2015 | 03:01 PM
Gary Lewis's Avatar
Gary Lewis
If you plug the PV hole you won't have any enrichment. If the carb is jetted about right when you want to accelerate more than gently the engine won't want to do anything. And it'll either refuse to do more or bog until the secondaries open. IOW, don't do it. Fix the problem, don't create another one.
So, getting 4 MPG @ 65 MPH with stock tires. That means you have a pretty significant problem - like the choke not coming off or a blown PV. Check the choke by getting the engine warm and then pulling the air cleaner. The choke butterfly should be standing straight up and down.
Old Feb 28, 2015 | 03:06 PM
tpvegas's Avatar
tpvegas
The choke is fine so I think I is the power valve
Old Feb 28, 2015 | 03:17 PM
Gary Lewis's Avatar
Gary Lewis
That would be the next thing to check.
RomerB2
Alternative Fuels, Hybrids & Mileage
84
Apr 8, 2019 11:31 AM
05 CO King Ranch
6.4L Power Stroke Diesel
28
Apr 28, 2009 03:38 PM
LoneRebel
Jan 14, 2009 10:33 AM
pac_302_xlt
Dec 1, 2005 01:30 AM
musclemike
Feb 1, 2000 11:29 AM
