Had a look in the manual 35-40-2, but don't have a clue how to wire it. Mine doesn't work. Want it to power my iphone or a camera.
The manual shows all needed parts but not a wiring diagram.
a, go to your local auto parts house (ie o'reilly's, autozone etc.) buy an aftermarket cigarette lighter assembly.
b, find a wire under your dash, that will only become "live" when key is turned to acc/run position,(you may even already have the oem wire with the connector there) then check your fuse
c, attach to cigarette lighter and then run a ground wire to under the dash
If you are installing a conventional socket, I recommend using 12ga wire. This will allow use of 12v compressor to blow up a flat or emergency lights, if needed.
there is a three-wire female conector just inboard of the glovebox within a few inches of the lighter which has both switched and unswitched 12v available.
