Titan vs Transfer flow
Old Jun 7, 2017 | 02:57 PM
  #46
Rebelz's Avatar
Rebelz
Again like I have said over and over again. You will be happy with either one. There is a reason both company's have survived. Pick one and go with it.
Old Mar 25, 2018 | 12:01 PM
  #47
VA13FX4's Avatar
VA13FX4
Digging up this old thread to see if anyone who has either tank has any feedback after having the tank for a while. I’m in the market for higher capacity fuel holding in some shape or form and like the idea of not taking up space in the bed. Thanks in advance for your input!
Old Mar 25, 2018 | 02:12 PM
  #48
f350ktm's Avatar
f350ktm
I installed the Transfer Flow last June and mine has been trouble free. No leaks or conflicts with the truck physically or electronically.
Here is a link to a thread I posted on the installation in case you have not found that through search yet.
Transfer Flow 60 Gallon Install 2017 6.7 CCSB
I don't foresee issues coming in the future but will certainly update that in my posted thread if anything does show up.
I will be using Forescan to modify the gas gauge and DTE readout and will post how that goes in that thread also.
As I wrote in the thread according to my research both Titan and Transfer Flow are viable options for these trucks. They each have their own advantages and disadvantages.
Good luck!
Old Mar 26, 2018 | 07:19 PM
  #49
VA13FX4's Avatar
VA13FX4
I’m curious if anybody with the 1st version fuel tank that showed empty when there was 5-6 gallons still in the tank has gotten one of these tanks? I’m not sure if I should have the dealer do the TSB before I get one of these tanks or if it matters.
Old Mar 27, 2018 | 07:30 AM
  #50
wiresLV's Avatar
wiresLV
4wd Low
I should have had the TSB performed but didn't. After installing the Titan at 0 DTE I can squeeze in around 48 gallons. I probably should have waited and got the TSB sending unit installed first but it's not worth the hassle now. I think of the extra six gallons floating around in there as "just in case".
Old Mar 27, 2018 | 08:05 AM
  #51
VA13FX4's Avatar
VA13FX4
thanks! That’s exactly what I was wondering. I’ll probably get it done since we about to drive cross country and even with the larger tank a 100 mile difference in DTE will matter.
Desert Dave
Aug 27, 2018 07:43 PM
eric.larson
Aftermarket Products
Sep 9, 2016 02:06 PM
mdr617
Bronco II
Nov 2, 2010 12:37 AM
Champ198
Aug 18, 2007 06:49 PM
