351m bent pushrods
Old Jun 2, 2017 | 10:48 AM
Filthy Beast's Avatar
Filthy Beast
See post #10 and then look at post #5...where the pushrods are on #1 exhaust and #2 intake. Nice openings in the head. Same with 3 and 4, 5, 6, 7 and 8. The smaller pushrods holes allow a magnet or Chinee fingers to get down to the lifter, pull it out and with the magnet and pick/screwdriver, one can maneuver the lifter over to the larger openings and pull' em out.
Old Jun 2, 2017 | 12:04 PM
beartracks's Avatar
beartracks
I guess I get it. There are usually too hard to get out with a magnet if they have been in a while and the grabber requires a straight shot. Good to know.
Be sure to put them back in the same hole.
I guess I made a mistake. I made one once in 1974 when I thought I was wrong but turned out to be right in the first place.
LMBO!
Old Jun 2, 2017 | 01:36 PM
Filthy Beast
Ahhhhahahaha!
Never use the "W" word...use "mistaken" instead. Us old bucks never are "wrong".....
(I'll wait with the popcorn for the female of the species to jump on that one!)
Good point on noting from which hole the lifters came.....if re-useable.
Old Jun 4, 2017 | 10:54 AM
1oldlongbed's Avatar
1oldlongbed
I pulled the lifters and checked them out for a second time. They are a little warn but no light from the middle. I used pb blaster (?) on the springs and the tapped the valves with a hammer. Some whent -thud- some whent -ting- so I lightly tapped them to see if I could get all of them to -ting-. Then i put the new push rods in and let her run. Everything looks good so far, just wanted to say thanks for the help.
Old Jun 4, 2017 | 11:02 AM
beartracks's Avatar
beartracks
If it's quite you will hopefully be good to go.
Old Jun 4, 2017 | 02:51 PM
LiquidCowboy's Avatar
LiquidCowboy
Looks and sounds good!
Old Jun 4, 2017 | 06:23 PM
Filthy Beast
You're welcome...and well done! Hope you have trouble free and 'Happy Motoring' days ahead.
Old Jun 4, 2017 | 07:48 PM
1oldlongbed
Thank you but I don't think I will be that lucky. I put the valve cover gaskets on today adjusted the new carb and ran it and it still smokes out the back. I thought after finding the push rods off the rockers it may fix itself but no go. It dose not have water in the oil and it runs good. The smoke is white but dose not smell like blown head gasket.
Old Jun 4, 2017 | 07:59 PM
Filthy Beast
When you 'goose' it, do you see clouds of white smoke, continually?
That video almost seems normal for exhaust when the engine is not up to operating temperature. Was she "cold" when you took the video?
And, if you care to take a whiff...does the exhaust smell...sweet?
Old Jun 4, 2017 | 08:07 PM
LiquidCowboy
Yes I agree with Filthy Beast partially if it's cold it could do that as it may be sucking condensation from crankcase. If it's continual after warming up could be another issue. Small Cam in it?
Old Jun 5, 2017 | 09:27 AM
beartracks's Avatar
beartracks
trany vac modulator?
Old Jun 5, 2017 | 11:53 AM
1oldlongbed
It's about 90 f out side and the truck was running for about 10 min. I noticed it when I started the truck for the first time. When I would rev it up it would get worse and was less when the truck was cold. But at that time the carb was shot and I had the pushrods problem. When I found the push rods off the rockers I was so sure that was the problem but its not. It's not a blown head gasket, the engine runs good, it's not blue like oil, it's not running rich. The only thing I can think of is if the gas is old. The guy told me he just filled it with 5 gal before it was towed to me but now in not so sure that gas is good. Can old gas make a car smoke?
As for a cam I have no idea what was done to the truck. The engine is a 1978 and I thought they ran rotators in 1978 so to me I think someone has been in the engine but I have no idea.
Old Jun 5, 2017 | 01:00 PM
  #28
KULTULZ's Avatar
KULTULZ
Post
Just a thought-
It has a rough idle for whatever reason. The smoke (possibly condensation) is most likely being produced as a result of the convertor(s). It should calm down after engine warmup. If not...
Does the gasoline smell like old varnish?
Old Jun 5, 2017 | 03:24 PM
  #29
LiquidCowboy
Could be a touch worn on the guides or stem seals, not enough for heavy blue smoke but enough for little puffs, old gas is a possibility but If it got worse after warm up I would have to think blow by or a top end sealing issue. Not necessarily enough for a full rebuild but a worn guide or burnt valve or two would add little white to the exhaust. Mine did that when I first got it (now prepping engine #6) but if it's a daily it's up to you how far you want to get into it
Old Jun 5, 2017 | 06:11 PM
  #30
Filthy Beast
A few things come to mind;
Old gas.....you betcha old gas will make an engine smoke....not like a SoCal grass fire in August, but somewhat like roadkill burning on the grill.......and smell very bad.
Exhaust rotators....yeupp, used in '78 and up stock M block heads. Chances are good that if they have been replaced, it was because an aftermarket cam, etc was installed. That video did sound like a "bigger" than stock cam.
I know you have a vacuum gauge...hook it up and watch what it tells you. You can eliminate or verify valve, valve guides, valve springs, ignition timing....etc...
grizzbilly
Dec 26, 2014 09:53 AM
mpc07005
Jul 17, 2012 09:09 PM
704 dentside man
Jun 13, 2010 02:37 PM
cjbronco
Dec 15, 2005 06:25 PM
ohiofossil
Mar 12, 2005 01:26 PM
