4R70W no forward, reverse good
Old May 31, 2017 | 03:27 PM
qdiesel75's Avatar
qdiesel75
Have a 99 F150 2wd 4R70W. Was slipping in first then finally quit. I rebuilt it, utilizing master overhaul kit. The clutches were worn all the way down, especially the forward drum so I figured fault was just high mileage normal wear. Reinstalled the trans, reverse is great but still no forward. If I raise rear wheels, therefore no load on it, then wheels do move forward and will actually get to a point where it shifts to 3rd.
I did do something stupid, as I didn't disassemble the fwd and direct drums and therefore didn't replace those piston seals. (Please flog me after answering my questions though!) Otherwise I replaced everything else. There was no evidence of physical damage ie snap ring, ring groove, etc. Obviously the piston seal is a mystery. I am confident I put it back together correctly.
I have learned through these forums that the problem is not electrical.
I am guessing that the fault is most likely the forward drum piston seal leaking by causing minimal fluid pressure to the clutch pack (just enough to engage with no load). I don't think the direct clutch would be a culprit since it works in revers.
Asking the experts if this sounds like the problem and can it be verified via a pressure tester connected to the port on the case?
Sorry this is long but didn't want to say "it's broke, how come?".
Thanks!
Chris
Old Jun 4, 2017 | 08:24 PM
qdiesel75's Avatar
qdiesel75
Well it looks like it was the forward drum piston seal. Got it out and apart yesterday and the seal had two spots where it was missing a small piece. Which fits the symptoms. Lesson learned the hard way but I'm glad I found definitive proof of a faulty part. Will prob get it back in the truck next week and will update with the results.
ArmyCook
13
Nov 11, 2024 10:06 PM
dreed1975
Feb 3, 2015 09:44 PM
RANGER 07
1983 - 2012 Ranger & B-Series
Aug 4, 2008 07:48 PM
Nick8564
Feb 15, 2006 05:37 PM
cappy
Jan 7, 2004 02:46 PM
