Working on a '65 F250 and trying to install a side gas tank from a '72. Does anyone have a diagram of how this pile of brackets and straps go together to put this in the truck?
I spent a couple hours under the truck and it's kinda close to fitting, but I believe I am missing some brackets or mounts.
Thanks
Does anyone have a diagram of how this pile of brackets and straps go together to put this in the truck? No such thing.
There's no related diagram or parts, because...
No 1966 or earlier pickup came with a factory installed auxiliary fuel tank. The only tank these trucks (1956/66) came with, was the in-cab tank.
Factory installed auxiliary tank introduced in 1967 F100/350.
1967/72: Factory installed auxiliary tank mounts on the inside of the left frame rail. 1967/69 tank has the fuel filler tube/fuel cap located above the scallop (bumpside) line.
1970/72 tank has the fuel filler tube/fuel cap located below the scallop line.
i have one on my 69 that doesn't work because someone cut all the hoses to try to steal gas,there wasn't any in there but they don't care . so how do i get replacement hoses?
The vent hose was part number C7TZ9170A. Discontinued. It was 3/4" I.D. fuel hose 16.5" long. This can be had at local parts stores sold by the foot in bulk form. Or you can buy the C7TZ9170A here:
Obsolete Reliable Parts
Part Number:C7TZ-9170-A
Seller:Obsolete Reliable Parts -
Phone (229) 686-5101
The filler hose was part number C8TZ9047F. Discontinued and none on my locators. Recently another FTE'r bought one for a Dentside and adapted it. I don't remember who. I believe he cut it in 1/2 and clamped a piece of metal exhaust pipe in the middle to lengthen the hose.
The vent hose was taped to the filler hose, and a tech told me years ago that if the filler hose was replaced with a 'gypo' hose and it wasn't taped to the vent hose, the vent hose could collapse.
This same jazz also applies to 1973/79 mid-ship & aft axle tanks that were a notorious slow fill from day one.
I don't remember ever seeing the C8TZ hose. I remember seeing and selling quite a few of both D5TZ hose assemblies. You are right. I remember those were taped together and also a metal protector guard taped on. I believe about the vent hose collapsing. From memory I don't think there was a hole lot of webbing molded in to the 9170's rubber. I am assuming current aftermarket 3/4" fuel hose would have the webbing in it.
Yes, I understand all of this, but the frames are practically identical, so I thought it would be worth a shot.
