Sponsored by: Real Truck
supercharging a 5.4 2V ?
Old May 31, 2017 | 07:01 AM
silversmith4's Avatar
silversmith4
Not looking to go power crazy. Just looking for better pulling power for my 99 250 SD. thinking about R&R engine/tranny w/new Ford remanufactured engine w/3/yr warranty & local rebuilt tranny. Say maybe 8psi max. Has anyone done it? If so, I'm interested type SC used & final outcome. Thanks.
Old May 31, 2017 | 07:32 AM
seville009's Avatar
seville009
Have you tried a tuner? May give you what you want with less hassle.
I put one in my 2006 5.4l and there is a definite improvement.
Old May 31, 2017 | 08:27 AM
redford's Avatar
redford
FTE Leadership Emeritus
Do keep in mind that the OP has a 2V engine. You have a 3V engine. Very different animals when you start discussing tuners.
Old May 31, 2017 | 08:56 AM
Mike1's Avatar
Mike1
All kinds of info on this, just do a google search for:
supercharging / turbocharging a 5.4L 2v ford motor
Although IMO, it would probably just be cheaper to buy a truck with a bigger engine, if you're looking for a bump in HP and torque.
Old May 31, 2017 | 09:02 PM
nogo73's Avatar
nogo73
This may be easier ... Ford F-250 5.4L Turbo Upgrade | DrivingLine
Unless you can get the lower intake for a lightning or Harley Davidson f150 everything else you would need to do different brackets or plumbing for the intake. This has been done and is easier if you can get all the parts. Just have to change a pulley to get desired boost.
Either way your looking at $5k plus, You should also consider replacing the bottom end to forged internals while your at it. 5.4 Pro Modular IRON Short Block
Old May 31, 2017 | 10:23 PM
Mike189677's Avatar
Mike189677
You need to realize that the big difference you experience in your truck is mostly because of the drive by wire. All trucks before 05 had an actual cable you have mentions this a few times with threads regarding the older trucks. The biggest diffence on those wil be in the transmission. So unfourtely your experience doesn't really apply here. Not trying to be a jerk just trying to clear the air. . Op P.I. heads and gears 4.30's with stock size tires would be a very good option for you before going the forced induction route.
cdgarage
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jul 4, 2019 02:10 PM
Rob75
Engine Swaps
Jan 18, 2018 07:42 PM
swellman
Jan 7, 2016 09:12 AM
howes925
Mar 26, 2008 08:46 PM
ZUGtastic!!!
Mar 4, 2005 02:51 AM
