Sync weather map
Old May 31, 2017 | 06:48 AM
rbsev's Avatar
rbsev
Sync weather map
we use the weather map feature quite often and have discovered our new F350 displays the map without the radar showing. Has anyone else experienced this, and have you found a "cure"? The navigation appears to be working, but haven't really had a chance to really try it out, but that will change in a couple of days. Our Sync is 2.2 if that helps. Our last two trucks worked flawlessly, and believe me we are not computer savvy, so any and all help greatly appreciated. The dealership couldn't fit me in to check it out!
Old May 31, 2017 | 07:26 AM
Uzumati's Avatar
Uzumati
Isn't it part of Sirius Traffic that you have to sub to in addition to Sirius Radio? Mine worked until the trial ran out.
Old Jun 1, 2017 | 06:19 AM
rbsev's Avatar
rbsev
I called Sirius first, and they said I was getting the service, and it has to be equipment related
Old Jun 1, 2017 | 10:14 AM
Joneser5000's Avatar
Joneser5000
These trucks come with 5 years of Sirius Travel Link service. Even if you do not renew your Sirius/XM subscription you will still have access to travel link and all its features
Old Jun 4, 2017 | 12:49 PM
Davydee's Avatar
Davydee
Been a few days. Did you find a cure? We haven't noticed any issues with ours, but have had to wait a few minutes for it to show weather on screen. David
Old Jun 4, 2017 | 03:19 PM
rbsev's Avatar
rbsev
No cure, all we see is a weather map without the radar. Traveling and need/want it, so will call and see if there is a reboot or some other possible reason/fix. Our last two Ford trucks both worked fine
Old Jun 4, 2017 | 03:46 PM
k7lvo's Avatar
k7lvo
I would power cycle the Sync system. It looks like fuses 32 and 33 on the fuse panel in the passenger compartment. With the ignition/accessory switch turned off and at least one of the front doors open, pull both fuses for,30 seconds or so. That should be a hard reset of Sync.
Old Jun 4, 2017 | 05:26 PM
inki's Avatar
inki
Do you have the radar enabled on the map screen. Seems obvious but I thought I'd ask.
The buttons on the screen towards the left side.
Old Jun 5, 2017 | 07:05 AM
Davydee's Avatar
Davydee
And those buttons don't show for long. On ours, I usually have to tap the screen a couple of times to keep them showing before I can ensure I've got them set the way I want. Also, on ours the button must turn blue to be on/active. David
Old Jun 5, 2017 | 09:11 AM
troverman's Avatar
troverman
You need to make sure you have the option for radar showing. It might be under "storm" or something like that. There are several options you can show or hide, like wind speed, etc. Also, make sure there is precip in your area or nothing will show.
Old Jun 5, 2017 | 09:57 AM
Shreve T's Avatar
Shreve T
There are 3 buttons in the left hand corner... Tap on them and it should start showing radar functions
Old Jun 5, 2017 | 04:26 PM
rbsev's Avatar
rbsev
Alright, got radar
I never saw those buttons, it's going to take me a little while to get used to the differences in operation. Thanks, I appreciate it
whagen
Mar 3, 2019 06:16 AM
tomsparks
2015 - 2020 F150
Mar 31, 2017 10:53 AM
lundman
6.7L Power Stroke Diesel
23
Mar 4, 2013 12:21 PM
Jimax
Nov 21, 2012 05:45 PM
Mud_Man_Dude
Jan 2, 2012 11:02 PM
