Completing a factory ac install
Old May 30, 2017 | 05:49 PM
Ruslan Shevchuk's Avatar
Ruslan Shevchuk
I've been driving my truck with all the ac parts installed but have not finalized the electricals. More specifically, the fuse box is missing the ac clutch relay.
This is an Alaskan f350 xl package with a 6.0 that I overhauled. It's a rare truck that didn't have ac originally so along with rebuilding the engine I've installed all the factory components of an ac system. The wiring to the sensors and compressor were all part of the engine harness, and I switched out the control panel for ac controls, but I'm now at the point where I need to either tear apart the under-hood fuse box or dig around for schematics to locate where a relay pigtail can be wired in. I figured I'd post here and ask you guys if anyone has had the relay box apart enough to guide me in locating that pigtail.
I'm assuming it's gotta be in there and all I would need is the terminals leading into the box, and a relay, since the fuse is already wired in.
Any ideas or suggestions?
Old May 30, 2017 | 11:47 PM
Yahiko's Avatar
Yahiko
Year and are you EACT or not?
Old May 31, 2017 | 09:05 AM
Ruslan Shevchuk
Thanks for the response Sean,
It's an 06 and please educate me on EACT, what am i looking for?
Old May 31, 2017 | 09:13 AM
Ruslan Shevchuk
If eact stands for electronic air conditioning control then I'm probably not since I've got vacuum control switches. Sorry bout the earlier brain fart.
Old May 31, 2017 | 06:48 PM
Yahiko's Avatar
Yahiko
Yep it the digital system for controlling the air in the cab.
I'll dig out the PDFs that you are looking for and post then a bit later tonight.
Old Jun 1, 2017 | 12:59 AM
Yahiko's Avatar
Yahiko
Ok got some PDFs for you to have a look at.
This is all from the 2006 Workshop Manual.
Old Jun 1, 2017 | 05:40 PM
Ruslan Shevchuk
Thank you for those Sean. I was able to determine which wires correspond to which pins on the relay. Do you have a diagram with physical wiring locations?
Old Jun 1, 2017 | 09:31 PM
Yahiko's Avatar
Yahiko
Not much to be had in that department it look like.
A/C Compressor Clutch Diode.
C2170F (CJB) pins 11 ground & 12 A/C clutch relay switched output.
The relay is this one in the BJB.
C1008
See attached PDF.
Staci Crandall
Sep 22, 2016 07:38 PM
SpawnX
1983 - 2012 Ranger & B-Series
May 25, 2014 08:11 AM
K0IRL
Sep 22, 2012 03:57 PM
f250d4x4
22
Aug 1, 2011 07:16 PM
jfboy
May 10, 2005 07:36 PM
