Power Windows wiring?
Old May 30, 2017 | 09:12 AM
Building_Fords's Avatar
Building_Fords
Hi all, I have been driving her now for 6 months, no issues, getting about 16 ,mpg, (87 custom I300 V6/C6) 2WD... so I am pretty happy with that... Now I am looking to add some things. I have the Power window wiring Harness for a 95 F150 and the doors with the Motors in them as well all I need is the Driver side door harness, (it was cut). My question is, How hard would it be to marry up the 95 Power Harness to the 87? I could pull the whole dash harness from the 95 donor, BUT that brings up other issues. If I have the controls on the Door, I should just need to have power to the main switch, grounds at both ends.. RIGHT? I am going to look at the wiring to figure out which one was supposed to be the hot wire, ( I assume 1 Hot to the main switch then it would be routed to the passenger door from there). I don't think it should be to hard, I have put power windows into an old truck before... BUT this is crossing years so I need to match things up... just looking for any advice...
Old May 31, 2017 | 09:14 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
EVTM - you need pages out of the EVTMs for both trucks. That's what I would do anyway. Google image search may hit on results for you.
The wiring is a little *******ized because of the switch on the driver's side to control the window on the passenger side.
omni
Mar 31, 2015 08:37 PM
skips69
31
Apr 30, 2010 12:17 PM
CdnSoldier
Aerostar
Apr 23, 2009 02:08 PM
jlutes
Electrical Systems/Wiring
Feb 23, 2009 10:19 PM
davidsca
Jul 8, 2006 05:50 PM
