Advice for putting new floormat in
I got a reproduction floor mat for my 55 F350. It does not have the perforations to cut out holes for the gearshift and the e-brake lever. And it is much thicker than the original mats.
So how difficult is it to get the mat over the gear shift, the e-brake, and the clutch and brake pedals, and the gas pedal. Is it a two man job? I can easily remove and put the mat in my 54 myself but that has the e-brake mounted under the dash and the column shifter.
Any tips or advice? Can the e-brake lever be removed?
So how does the gear shift lever come out?
Received 4,134 Likes
on
on
My first (non experienced) thought was to use some sort of duct tape type product to cover the entire top surface of the old brittle one, to hold it together B4 you carefully removed it. A few rolls of duct tape are pretty cheap, then use it as a template. But paper sounds like it would probably be a lot easier. Just thinking out loud, which can be dangerous.LOL
on
on
52' fordnut
03-26-2013 08:03 AM
hrp77573
05-16-2010 03:36 PM
