Axle Ratios
Old May 29, 2017 | 06:52 PM
Abomb0012003's Avatar
Abomb0012003
Axle Ratios
So I am in the middle of a frame off resto with little to no knowledge of what I am doing, just really doing it to learn and hopefully to end up with a really nice truck! Anyway trying to order some replacement parts for my Dana 44 late year 1977 F250 front axle and it is asking if the gawr is 3300 or 3500? Any ideas?
Adam
Old May 29, 2017 | 07:23 PM
Blue and White's Avatar
Blue and White
The data plate on the door will help. Have a look and take a pic and post it.
Old May 29, 2017 | 07:52 PM
Abomb0012003
This?
Old May 29, 2017 | 08:31 PM
Blue and White
Here is a site that helps decode data plate info. Per the decode (I am not an expert!) GVW is 8,100# and rear axle rating is 5,300# so front is 2,800# according to Ford. Dana may rate the axle higher but springs or other considerations may reduce the front rating.
1973-1979 Ford Truck VIN Tag Codes (Rear Axle) - FORDification.net
Old May 29, 2017 | 08:40 PM
tabascom16's Avatar
tabascom16
Not sure what that all means. Could be the difference between the half ton 5 lug and the 8 lug version?
What parts in particular are you ordering?
Old Jun 1, 2017 | 09:49 PM
Ozzie H.'s Avatar
Ozzie H.
Adam
Get the information from the ID tag for the axle assembly, and I will try to get the capacity for you from the parts book. The tag should be attached between two of the cover bolts, and should look like this (except this one is for a rear axle and is slightly different):
On the upper left portion of the one for the front axle should be the Ford production part number. Below that should be the Dana part number. Get both. On the right should show the production date and the ratio. Sometime the tag can be corroded and/or full of crud. Do your best to restore it so it can be read. This tag should remain with the axle.
Old Jun 1, 2017 | 10:05 PM
PapaBearYuma's Avatar
PapaBearYuma
The front must be "not less than" 2800, but will be of higher capacity. The ratings for the front and back combined will be higher than the rated total because nobody loads the truck perfectly. The center of gravity is all over the place-may be forward or may be rear. Ten percent may be a sufficient margin of error, so it's at least 3100 capacity
Old Jun 2, 2017 | 01:44 PM
mark a.'s Avatar
mark a.
I'm no expert either but the 8100 is a dead give away that it was built with a Dana 44 front axle, so the 3500 must/might be built with a Dana 60 front ? Funny it is only a 200 pound difference though.
Gramps67highboy
Feb 5, 2015 12:35 AM
helipirate
May 31, 2011 06:13 AM
Lukes66
Aug 23, 2009 11:38 PM
prairietk
Jan 2, 2007 06:22 AM
cies_69truck
Nov 10, 2002 01:59 PM
