NO start issue. Odd problem.
Old Oct 4, 2017 | 12:02 AM
rhett porter's Avatar
rhett porter
Originally Posted by Montync
1984 f150 XLT 2WD Auto
I have a very very odd problem.
Rewind to 2.5 month ago:
I had no power to my radio in with the key in accessory.
-the truck always started though.
I loosened the bolt to the ignition switch adjusted it until I got power in acc. and sprayed all the old chunky grease out of the key switch/tumbler
Fired right up time after time. I then let the truck sit for about 2.5 months
Today I go to crank the truck:
-No starter nosie, no turn over nothing
-Put it in neutral tried to crank, nothing
-let off the ebrake put it in park tried again nothing
***Lights dimmed when trying to start (still no starter crank)
I left the key on, and tapped the s terminal, The starter began to turn
-Hooked the S solenoid wire back up, tried to crank nothing
Turned the key on
-Jumped the S terminal the truck fired up
Turned the truck off
Turned the key, and it fired up
done this about 15 more times
Had I not jumped it, It would have never started. Jumping it seemed to fix the no start issue buy why?
anyone ever have a similar issue?
Thanks
My 1987 f150 xlt lariat is doin the same had it sit for a month now no crank no start no clicks no dash, headlights turn on and so does the dome light but nothin else, battery is charged and good, brand new selonoid and starter................... how did u jump the s terminal?
Old Oct 4, 2017 | 01:00 PM
FuzzFace2's Avatar
FuzzFace2
From battery positive side with a wire.
Dave - - - -
Old Oct 22, 2017 | 03:00 PM
James Wagoner's Avatar
James Wagoner
Just got myself in the same boat... Truck started like a champ all day yesterday when I bought it. Today not turning over but good battery, fuel pumps going, lights, etc.
I'll see if jumping the terminals will work for me.
Old Oct 22, 2017 | 05:56 PM
FuzzFace2's Avatar
FuzzFace2
Being the truck is new to you I would replace all the batt. cables as a start.
You can not look at them to tell if they are good or not as they go bad inside out. When you get them replaced cut one open and see.
Dave ----
Old Oct 22, 2017 | 06:14 PM
James Wagoner
You are correct, I do need to replace those things out of principle.
FYI - Started a thread - https://www.ford-trucks.com/forums/1...5-f-250-a.html - so I will post findings there and not double post.
David Llanos
2015 - 2020 F150
16
May 7, 2021 08:36 PM
Bakernator
Jul 8, 2016 10:46 AM
cookingguy
Apr 20, 2016 06:58 PM
cag1980
Sep 29, 2008 09:12 AM
73strokin
Oct 28, 2007 09:21 AM
