Sponsored by: Real Truck
No Air Conditioning - Sometimes
Old May 28, 2017 | 05:16 PM
jdinner's Avatar
jdinner
Yes, I used the search function. No results.
2011 F250 - AC works perfect sometimes.
When it does not there is not clutch action or signal.
Pressure is good, will work for many hours when working.
Sometimes it will not turn on at all.
I'm looking at installing a resistor in the evap temp sensor circuit.
Any other ideas?
Old May 29, 2017 | 03:34 AM
seville009's Avatar
seville009
I've got a 2011 F350 that the a/c is not working. Tsking it in next week. Will let you know if it's something simple (i think the compressor died though - don't hear it clicking on at all)
Old May 29, 2017 | 10:26 AM
alloro's Avatar
alloro
When it won't turn on did you run the EATC built in diagnostic routine? If so what codes did you get?
Old Jun 3, 2017 | 09:24 AM
jdinner's Avatar
jdinner
I have no idea what that is....explain please
Old Jun 3, 2017 | 09:39 AM
seville009's Avatar
seville009
http://www.idmsvcs.com/2vmod/eatcswap/selftest.html
Old Jun 3, 2017 | 02:04 PM
jdinner's Avatar
jdinner
My truck is a 2011 F250. I don't think the EATC is possible for this year.
Old Jun 4, 2017 | 05:32 AM
Bugzilla46310's Avatar
Bugzilla46310
My 2000 F250 had a similar problem. It's been a while but if I recall, there were 2 relays, one on the high pressure side and one on the low pressure side. If they were going bad, you would get similar symptoms as to what you have. I thought the told me to try the low pressure one first and if the problem persists the try the high pressure relay. They were about $15 each. Just pop the old one out and the new one in. Not sure how different you system would be from the 2000 model.
BigRed7.3l
Jun 7, 2014 12:37 PM
icesimpson
May 27, 2014 01:13 PM
07Cruzer
Mar 11, 2014 03:26 PM
Jaime74656
16
May 2, 2012 01:30 PM
Stroked99
Jul 31, 2009 08:09 AM
