Battery runs down
Old Sep 3, 2003 | 08:15 PM
nancyan's Avatar
nancyan
Battery runs down
HI,
I have a 1988 f150 4wd and the battery will not stay charged. I have been through 3 new batteries that are so run down that I can't get them to take a charge again. It usually goes dead in 2 to 3 days. The alternator appears to be new and I don't see that there is any after market wiring that has been added on. Is there something obvious that I should look for or just give it up and take it to a garage? When I initially put the cables on the battery I hear the fuel pump kick on and that is all.
Thanks.
Old Sep 3, 2003 | 09:07 PM
John W Cina's Avatar
John W Cina
Battery runs down
I have a 1991 F150 4.9 with a 5spd and I to have had trouble with a DRAIN on the BATTERY running it DEAD after a few days.
I just had to replace the battery under warrenty - I believe the running it dead prematurely ruined the battery.
I have put a disconnect on my battery when not using the truck for a few days.
I connected a CURRENT meter and have read a CURRENT draw of 300 milliamps which I feel is a little high .
I wonder what the NORMAL current drain on the BATTERY when sitting maybe ????
So far I havn't tried to figure what could be drawing when the vehicle is just sitting..... Anyone had this trouble ??? John
Old Sep 3, 2003 | 09:27 PM
sparky's Avatar
sparky
Battery runs down
Just a thought but if the key is off why is the fuel pump running???
Makes me think that the igntion switch isnt going all the way to the off position.
Hook a meter or a test light between the negative post on the battery and the battery negative wire, disconnect the negative wire first.
Now if you have voltage or the test light glows something is drawing power.
So pull fuses one at a time until the meter reads 0 or the light goes out. The one that kills the meter/light is the problem circuit.
Dont forget to make sure the cab light and or underhood light is off before you start fault finding....can you say "wid goose chase"
Also try disconnecting the alternator, it can cause a drain if it has failed internally.
Good luck.
Old Sep 3, 2003 | 11:23 PM
John W Cina
Battery runs down
I just got thru searching old POSTings and see that the ALTERNATOR has been the culprit many times---I suppose one of the diodes shorts --which will still allow it to charge but now its not isolated as well with the lose of a diode so we get a current draw/drain thru the alternator winding---sort of like with a GENERATOR our CUTOUT CONTACT ON THE REGULATOR would stick pumping current into the generator...
I'm going to check mine in the morning... Thanks
northwindone
All Things Towing
Aug 22, 2016 11:02 AM
DIYiT
2009 - 2014 F150
19
May 26, 2016 12:47 PM
seventyseven250
All Things Towing
19
Mar 18, 2015 08:28 AM
Science1974
Oct 17, 2014 08:51 AM
GT40NUT
32
Aug 30, 2014 05:40 PM
