battery isolator question
Old Sep 3, 2003 | 12:52 PM
_GEEZER_'s Avatar
_GEEZER_
Does anybody know how to test a battery isolator (to see if it is operational?) Also to test what the max amperage it can handle??
I found one at the junkyard today. TEN BUCKS! Looks to be almost brand new, but I'm not sure if it's gonna work for my application. Thanks!!
Old Sep 3, 2003 | 01:43 PM
Mil1ion's Avatar
Mil1ion
Check continuity >
1) One test lead to center post >the other to first One end terminal then the
2) center post to the other end terminal
*Should show continuity*
Now check for one end terminal to the other end terminal
(This test should not show any continuity)
Old Sep 4, 2003 | 12:35 AM
13hondacr250's Avatar
13hondacr250
Should be stamped on it somewhere. If you can' tell don't use it. No need for a fire. Test light works good to to see if it works right.
