Got Codes?! I do.... :-/
Old May 27, 2017 | 01:08 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
it exercises the turbo while in park. Not at start up. You would notice it if you had it.
Old May 27, 2017 | 01:13 PM
amdriven2liv
Here is the tsb on the vane sweeps.
http://www.powerstroke.org/forum/att...ous-issues.pdf
Old May 27, 2017 | 01:34 PM
diesel_dan's Avatar
diesel_dan
A little more info: I was only looking at my 1st file where I saw both VGT at 85% and 15% (latter several times). The 85% looks to be around the time I reset the CEL faults and I never saw those high of numbers again, in either file.
The 15% ones look to all be around when I was really romping on it and mostly either after a shift or when I chopped the throttle.
Then after my lunch stop I had a mostly down hill run back home, lowest VGT % was in high 30s and highest was like 76%...
Turbo whistle sounded very normal: changing with any throttle change, etc.
Maybe I'm making myself more paranoid....
Scott
Old May 27, 2017 | 01:41 PM
diesel_dan's Avatar
diesel_dan
Thanks Sean: I scanned through the TSB and I don't think I have that version. I would think I would see the sweep on my torque log file, unless it needs to run an hour before doing one (a sweep).
I may take the truck down to my folks and do the same logging and see what I get -- it's a 2 hour trip each way...
I assume since my truck is out of warranty, I can't go in to Ford and ask them to perform the TSB, right?
Old May 27, 2017 | 02:02 PM
amdriven2liv
I think they would charge $100 to flash it.
I did a video on 18 gauges while doing multiple wot runs for each group of gauges.
At 2 minutes in the video you will see me kick my vgt down to 14.
Old May 27, 2017 | 03:51 PM
diesel_dan's Avatar
diesel_dan
Thanks for sharing that, Sean -- makes me feel better!
Scott
Old May 28, 2017 | 02:40 AM
WatsonR's Avatar
WatsonR
30-76% is a good range. About what I see on a new turbo, but no sweep here to speak of.... if that helps Scott.
Old May 28, 2017 | 11:06 AM
diesel_dan's Avatar
diesel_dan
Yes it does, thanks Randy
I'm still wondering how much hunting at idle mustang_309 was getting...
Bottom line is the truck needs to get driven more regularly!
Thanks guys ,
Scott
Old May 28, 2017 | 01:27 PM
mustang_309's Avatar
mustang_309
Thanks guys ,
Scott
The hunting at idle wasn't as pronounced as it was stead state driving at say 65 MPH. sometimes the VGT% at hot idle would start at 70 to 85 % and slowly drift down to the low 60's. While driving stead state at freeway speed it would hunt from 45 to 60% or so, when I first got the truck it would vary from 50 to maybe 55%.
Old May 28, 2017 | 01:35 PM
diesel_dan's Avatar
diesel_dan
Thanks for the follow-up -- I'm going to keep monitoring this until I feel more comfortable it hasn't gone whack on me... I'll be able to look at the steady state on a flatter fwy trip.
Thanks again,
Scott
on edit: go figure, I was actually able to rep you!!!
Old May 28, 2017 | 02:00 PM
mustang_309
Thanks again,
Scott
Sweet thanks bro.
AggieFord
6.7L Power Stroke Diesel
Aug 22, 2020 10:23 AM
the_auto_tech
Sep 1, 2014 12:16 AM
landscapeguy
Jun 14, 2014 08:30 PM
HollywoodRCFD
Mar 1, 2014 02:16 PM
xccxsinnerx
20
Dec 16, 2008 05:21 PM
