flywheel for H 6 flathead
Old May 26, 2017 | 07:52 AM
Ricardo Chambers's Avatar
Ricardo Chambers
does this look like it will work for an H?
Old May 26, 2017 | 08:38 AM
raytasch's Avatar
raytasch
Believe Nothing
I believe your crankshaft has four attachment bolts, does it not? Four bolts and two alignment dowels? Measure to be sure. I don't know about outside diameter or tooth count.
Old May 26, 2017 | 08:45 AM
Ricardo Chambers
flywheel
yes it does
Old May 28, 2017 | 10:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
8HT-6375 .. Flywheel-with 114 tooth ring gear-Use with 11" clutch / Obsolete
1948/51 F1/F6 226 I-6 / 1950/53 254 I-6.
Old May 28, 2017 | 12:29 PM
Ricardo Chambers
Bill, I have a shot at a '47 G, engine, trans, and everything in between.
Would the G drive train fit an H engine?
Old May 28, 2017 | 08:01 PM
Marauder2004's Avatar
Marauder2004
If I remember correctly, I believe you will need a 112 tooth gear.
Old May 28, 2017 | 08:23 PM
3twinridges's Avatar
3twinridges
Either a 114 or 112 tooth will work, but the starter drive will need to be changed to compensate. I think the 114 is the most common for the 226 and gives it a lot of torque to fire it off. But I have spare 10" 226 flywheels with 112 also and spare 112 ring gears.
JB
Old May 28, 2017 | 09:37 PM
Ricardo Chambers
JB
I appreciate the response.
Old May 28, 2017 | 09:46 PM
3twinridges
watch ebay and a 226 flywheel will pop up for you. Depending on the truck you are using be careful about which size you are getting, 10" vs 11".
Old Jun 1, 2017 | 04:31 PM
Ricardo Chambers
good news and bad news
GOOD NEWS: The flywheel from the G is on the H
BAD NEWS: The flywheel is from a V8, 112 teeth
GOOD NEWS: Interchangeable parts!
OBS Mule
Mar 5, 2017 09:42 AM
AtlM5
May 16, 2015 08:36 PM
dlb.motorman
Aug 21, 2014 08:08 AM
crazy96863
May 1, 2013 07:38 PM
c4barnes
Sep 8, 2009 05:34 PM
