Started searching but couldn't find the answer that I'm looking for. Looing for someone that has the powerslot cyro rotors with a good amount of miles on them. Just wonder how they are holding up. Really thinking hard about them and how long they usually last.
Aftermarket rotors are generally much better than stock. My non-cyros have 8k on them and still going strong. I wouldn't do them again, I am hoping for a set of performance friction two piece rotors. Slotted and drilled is more about the cool factor than heat dissipation and if your running good pads and know how to break them in, you don't have the de-gassing issues.
I am doing rotors and pads this weekend. I searched and read about the rotors. I am going back to OEM rotors and pads. The have lasted me 117,000 miles and still have some pad left. The OEM are 850.00 for front and rear, rotors and pads. I will also get a couple of caliper pin sets for incase some are bad. I am also doing the auto hub clean and grease. You know how much just the POWER SLOT rotors and HAWK pads are. I think around 1500 for the set, for my 1-ton 4x4.
Good luck on your decision.
I put the Hawk LTS pads and the Powerslot cryo rotors on my '99 F250 Superduty a year ago(20,000 miles ago) and the pads still look new after checking them yesterday. Cost of pads and rotors for all 4 wheels shipped to my door was $710.
