Sponsored by: Real Truck
Check trailer light keeps coming on
Old May 25, 2017 | 03:48 PM
Danielsm17's Avatar
Danielsm17
The check trailer light keeps coming on even though I don't have a trailer connected its annoying and I wanted to know if anyone had an idea how to fix it. Its a 2006 f250 with the 5.4
Old May 25, 2017 | 04:10 PM
Chuck's First Ford's Avatar
Chuck's First Ford
dirt or water in back of 7 pin connector for trailer.
Old May 25, 2017 | 08:06 PM
Danielsm17's Avatar
Danielsm17
I checked them theyre fine but when ever the tb module is bumped it sends the message to my dash
Old May 26, 2017 | 02:06 PM
droldsmorland's Avatar
droldsmorland
With the trailer all connected up to the truck put the trailer wheels in the air and actuate the brake controller (with the truck key on of course) and try to spin the tires. If one doesn't spin there's the problem. I'll bet the connection to one of the brakes is open or intermittent. Wiggle wires on both sides. If the brake wires are terminated at the brake plates with "scotch locks" that's the first place to look. I cut out those junk connectors and recrimped with butt shrinks with die electric grease stuffed inside then shrink tubed over all of that. Bulletproof now.
I used a small C-clamp with electrical tape padding both sides then slipped it over the thumb switches on the controller. I also moved the seat forward and wedged a pry bar between the brake pedal and the seat but now that I think about it that's not necessary.
Old May 26, 2017 | 02:07 PM
Danielsm17's Avatar
Danielsm17
Originally Posted by droldsmorland
With the trailer all connected up put the trailer wheels in the air and actuate the brake controller (with the truck key on of course) and try to spin the tires. If one doesn't spin there's the problem. I'll bet the connection to one of the brakes is open or intermittent. Wiggle wires on both sides. If the brake wires are terminated at the brake plates with "scotch locks" that's the first place to look. I cut out those junk connectors and recrimped with butt shrinks with die electric grease stuffed inside then shrink tubed over all of that. Bulletproof now.
it happens without a trailer and it seems to with the controller itself. The slider when touched or shook trips the warning message.
Old May 27, 2017 | 03:26 AM
seville009's Avatar
seville009
I think he was suggesting that you hook up the trailer to test the brake wiring in case that was the cause of the issue when then trailer wasn't connected (ie: bad wiring may be sending the false message)
Old May 27, 2017 | 06:14 AM
RV_Tech's Avatar
RV_Tech
Given that you know it is the controller itself, check the connections on the back or replace it.
Steve
Old May 27, 2017 | 11:24 AM
Danielsm17's Avatar
Danielsm17
Steve
I would prefer to fix it if possible. Its $550 to buy a replacement
Old May 27, 2017 | 01:11 PM
finn's Avatar
finn
There's a u tube video in which a guy found a broken solder joint on the slider switch.
There's also someone on eBay and some other sites who sells a remanufacturing service to repair controllers that show a fault code. Cost is $99.
I suspect it may be the same repair.
I spent several hours on the web trying to find a solution to why my controller works when squeezing the tabs manually, but is largely ineffective when braking normally, even when set at max gain. There are threads in many forums going back to 2005, but no definitive solution. ( the fault issue came up several times in my search for a solution to my own issue).
Old May 27, 2017 | 06:12 PM
RV_Tech's Avatar
RV_Tech
I think one of the guys on the Towing forum had his rebuilt.
Old May 29, 2017 | 04:45 PM
Danielsm17's Avatar
Danielsm17
ill check the slider a broken solder is an easy fix thank you
seventyseven250
All Things Towing
13
May 22, 2017 09:24 PM
dixoncity
6.7L Power Stroke Diesel
23
Aug 30, 2011 09:22 PM
Hurricane Ditka
Aug 23, 2011 10:49 AM
jmcder53
Electrical Systems/Wiring
Feb 9, 2010 06:04 PM
TrekChick
Jun 28, 2009 06:35 PM
