01' V10 Heads upgrades?
Had my 2001 v10 superduty in the shop for a blown plug repair.
The shop screwed up this repair and burnt a valve.
They are now paying for a bigger shop to remove the cab and pull BOTH heads and send them in.
I just curious if anyone had any recommendations on any upgrades that would be best to do now while the cab is off and while the heads are in the shop.
Truck is 6" lift on 35's, king cab long bed.
Has K&N filter.
future ups are SC Tuner and Exhaust.
Thanks!
Has K&N filter.
Thanks!
Definitely have the exhaust manifold studs replace or upgraded. I read on this forum about a guy that had larger diameter studs installed. I can't vouch for the results. But it's intriguing. At the very least you should have them ALL replaced with new.
Along the same thoughts- get your exhaust manifolds checked with a straight edge, and lightly machined if they're out of spec. I suppose it can't hurt to get the straight edge on the head port surface also.
All these suggestions are obviously related to the problem with the studs. As far as other improvements- you could check into the "usual" performance improvements like machining the heads for increased compression, replacing camshafts for better breathing, increasing the port size, etc.
but honestly in my years on this forum I haven't seen anyone actually DO those things.
Along the same thoughts- get your exhaust manifolds checked with a straight edge,.
Though I was meaning more about power ups, exhaust bolts are a issue on these things so I've read.
Thanks!
THANKS!
Why lift the cab off to pull the heads. When I had a shop do my heads..........it took them about 3 hours to pull them both without pulling the motor or lifting the cab. Had all valves replaced in my heads plus all steel inserts for the spark plugs....plus ne valve springd and both heads resurfaced.
No clue, it is on the other shops dime.
You read correctly. It will be 10,000 time easier to replace, even upgrade, the exhaust manifold studs while the heads are on a bench.
UPGRADES, yes there are some upgrades you can do.
Valves are the same as in a 2V V8 modular motor. So you can put 1 or 2 mm larger valves in it. That will make it breath a little better.
You could put custom cams in it. Comp cams will custom grind them I think as they sell V10 cam cores.
I would put premium valve guides in it and enlarge and radius oil return holes.
And id be very leery of changing the oil return holes. Unless there is a known issue I haven't heard of. It's a great idea for racing, where rpm is constantly high, but changing a street vehicle lubrication design is risky.
